1977 Southwind 18 motor mounts |
SouthwindLover
Newbie Joined: September-08-2014 Location: New York Status: Offline Points: 7 |
Posted: May-27-2016 at 1:11am |
I have a question. I have noticed that my motor has vibrated off the rubber motor mounts and I'm not sure why or how to go about fixing the issue. I have not felt any extra vibrating and the drive shaft still seems to be where it needs to be. And thoughts would be greatly appreciated!
Joel |
Joel,
Knowing more about what engine and mounts you have will help but it sounds like your rubber mounts are in need of replacing. If this is true, here's a source of some rubber replacements. Also if true, I doubt the prop shaft is where it "needs to be" I highly recommend not running the boat until the rubber mounts are replaced and a complete engine and shaft alignment is performed. Post some pictures. Please be aware that if you run the boat with bad alignment, it can and most likely will cause damage to other components like the cutlass bearing, prop shaft, shaft trans coupling shaft log and even possibly transmission damage. |
