  New Posts New Posts RSS Feed - 89 SN 2001 - pulls to the left
Goldenjc97 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goldenjc97 Quote  Post ReplyReply Direct Link To This Post Topic: 89 SN 2001 - pulls to the left
    Posted: May-27-2016 at 10:53pm
Hey guys,
When we purchased the SN about a month ago we noticed it pulled to the left. We had quite of other work to do first so it was put lower on the list. Now I'm wondering what could cause this and how to fix. I believe the prop is stock but not sure if that is what would cause the hard pull to the left.
Blamey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blamey Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2016 at 10:55pm
It's by design, positive pressure help driving straight in the ski course.
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2016 at 11:43pm
How hard does it pull? Mine pulls just slightly, as per design intent stated above.
Maybe you have bent rudder. You can grind 1 side to affect it, but it would be best to figure out exactly what the problem is 1st.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2016 at 11:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goldenjc97 Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 12:31am
Thanks guys - I did read there is a natural pull but if I let go of the wheel it turns dramatically to the left. Does that sound right?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goldenjc97 Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 12:37am
Not to derail, but I also have to keep the throttle pushed down or it returns to the top. Is this normal or should I be able to push it to a certain spot and it stay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blamey Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 1:17am
That's not normal. It should stay.
96 Super Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 7:56am
Not true. Quite normal for it to pull back, though not all will. Depends on the strength of the return spring.
Non-neutral steering is likely due to a tuned rudder.
