  New Posts New Posts RSS Feed - Tripping Main Circuit Breaker
sstichter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sstichter Quote  Post ReplyReply Direct Link To This Post Topic: Tripping Main Circuit Breaker
    Posted: June-14-2016 at 1:03am
We were out today running the boat and the stereo. The stereo is on the accessory breaker . When I turn the ignition off, the 40 amp circuit breaker in the electrical panel is tripped. I have to wait for the engine block to cool (or, at least 5-10 minutes to pass) until I can push the red button to reset the breaker. Any ideas?
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2016 at 2:45pm
breakers operate on heat, so it's possible that you need a new breaker because of it's age/condition.     Seems like you may have an ignition short also, as it sounds like the breaker trips with the cycling of the key....   I think some more description is necessary to really narrow down the issue.
-recurring issue?
- Battery voltage/condition?
- Wire condition (large main wires corrode, and cause a heavier amp draw)
- recent modificaitons?
- electrical system maintenance?
- clean/tight connections under the dash?
