  New Posts New Posts RSS Feed - Need Advice on changing filter
1998Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1998Nautique Quote  Post ReplyReply Direct Link To This Post Topic: Need Advice on changing filter
    Posted: June-21-2006 at 9:42am
I purchased my fuel water seperator filter, and was wondering if there is any tricks to changing it, my filter is located in the FCC canister. There is alos about a 1/4 tank of the old gas left, should I run it down to empty before I change the filter, or just top it off with fresh gas and change it then? I will also add injector cleaner.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-21-2006 at 12:33pm
Just go ahead and change it out at any time. I have heard that the cannisters are a bear to remove from the housing. Most have to remove the entire FCC and put it in a vice and use brute strength with large tools.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1998Nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-21-2006 at 12:57pm
Do I have to fill the canister with gas when I put it back in?
heycrummy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heycrummy Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2006 at 9:39pm
You do not have to fill the canister with gas.
