  New Posts New Posts RSS Feed - Motor got hot
Motor got hot
bwill14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwill14 Quote  Post ReplyReply Direct Link To This Post Topic: Motor got hot
    Posted: June-23-2006 at 11:30am
Hi all,
My water intake filter on my 81 SN got clogged yesterday. Before I realized it, the motor was HOT, hit 240 and stayed there even after I shut it off. After cooling down, the motor started and seems to be fine (have only ran in neutral).
2 questions:
Anything I should check or do since it was so hot?
If for whatever reason a motor gets real hot, what are the best steps to keep from damage?
Thanks.
Brent
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2006 at 11:56am
There are many threads on overheating. Try the search and your questions will be answered.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2006 at 12:05pm
as long as you waited until it was completely cooled before you started the motor then there's not much to worry about, just check for melted hoses and replace if needed.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2006 at 1:49pm
I would add, that you should keep an eye on the water for oil for a while incase you toasted a head gasket.
-Joe.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2006 at 4:02pm
Most likely a warped head, which would blow the gasket.
Tim D
MaddMarxx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2006 at 8:31pm
I just had that problem, i blew the manifold gasket and melted a spark plug. check those two things, very simple thing. you shoud tighten the manifold bolts once a month!
