  New Posts New Posts RSS Feed - 1991 Barefoot engine problem
davidrupp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidrupp Quote  Post ReplyReply Direct Link To This Post Topic: 1991 Barefoot engine problem
    Posted: July-09-2006 at 7:48pm
I have a barefoot with a 454, ecm just recently quit, replaced with a distributor and coil, but engine still doesn't run good. Nautique sells a conversion kit to do same, has anyone ever used it?
Dave
Bradley950 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradley950 Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2006 at 10:44am
When you say dosen't run good what do you mean? Are you talking about using the convertion kit, what kit?
Brad Miller
bradley950@yahoo.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidrupp Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2006 at 12:27pm
Nautique offered a conversion kit, a mallory distributor, coil, wiring harness for $700.00 I bought the items thru Summit Racing for $200.00 The wiring is pretty basic to bypass the existing wiring. The engine misses really bad, and won't idle.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradley950 Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2006 at 11:27pm
Have you cheaked the timing? Did you pull the dist.? Is the firing order right? Just some questions so we can figure this out.
Brad Miller
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2006 at 9:46am
I assume you used a marine distributor? That shouldnt affect how it runs, but an automotive unit would be a safety hazard. I agree with Bradley950, check the simple things first- start with the firing order.
