How to test if oil pump is bad? |
swanbomb
Newbie Joined: July-05-2017 Location: Madison, WI Status: Offline Points: 15 |
Posted: July-07-2017 at 3:26pm |
5.8L 351W PCM 1993 sport nautique
MACS81SN
Senior Member Joined: May-27-2009 Location: NW OH / S. MI Status: Offline Points: 109 |
Temporarily hook up mechanical pressure gauge in place of oil. pressure sending unit. What makes you think oil pump is bad? Pretty hard to wear out oil pump in these boats with the low hours most of them get.
1999 -SN - 502 Python 1981 - SN Owned 33 years - Sold 1968 - Mustang - Sold |
swanbomb
I am getting the dummy alarm and check engine light on intermittently.
So far I have tested the impeller, replaced oil sending unit, replaced the thermostat, and nothing has changed... What other things could I possibly test to rule out mechanical. |
MACS81SN
Bad or corroded wire connections can cause that. Lots of threads here regarding this issue. Neighbors 1990 sn has that same issue. Really annoying to drive his. Just waiting for some time to show him how to run a new positive and negative wire fromengine to dash. His voltmeter will drop to 10-12 volts if you turning anything on.
swanbomb
Thanks. I will check it out!
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1115 |
He has already been given that info but apparently he wanted a second opinion.
old thread Since both the engine light and oil pressure gauge indicate a problem it was a waste of time changing the oil sending unit. |
swanbomb
Hey desert. The Oil sending unit actually fixed the gauge from chattering. Didn't actually fix the beeping and overheating/oil pressure light, No I am just assuming it will be the electrical issue. I am going to ground the dash to the engine block. This weekend.
desertskier
Thanks for letting us know! So why do you want to check the oil pump if the gauge is reading correctly?
Since the engine light is driven by the switches you can disconnect them, run the engine and see if the problem goes away. The switches short to ground when a fault is detected, either low oil pressure or high water temp. You can also simulate a fault by touching the wire to ground (engine block etc..) and the light/alarm should turn on with the key on. The dash gets it's ground from the engine through the main harness. You can also try disconnecting the main engine harness plug, cleaning it and reconnecting it. If you have some electrical contact cleaner then spray some in the connector before plugging it back together or use some isopropyl alcohol.. There is also a main connector behind the dash which you could also clean. The permanent fix for dash power and ground problems is to run additional power and ground wires from the engine to the dash. |
