Correct prop size? |
Page <123 |
Author | ||
gt40KS ![]() Gold Member ![]() ![]() Joined: August-05-2017 Location: Wichita Kansas Status: Offline Points: 943 |
Ha ha ! Funny stuff Gary.
Yes, It's been a while since I've been around these types of 'spirited discussions'. They can be quite informative. And entertaining ... LOL |
JCCI
1995 Ski Nautique GT40 |
gun-driver ![]() Grand Poobah ![]() Joined: July-18-2008 Location: Pittsburgh, Pa Status: Offline Points: 4117 |
I have no idea on how they expect you to hit the end of the puller when you can't even get a socket and ratchet between it and the rudder.
![]() There's more than one way to skin a Democrat, (whoops I meant cat) I have found that the heat method works quick and easy with less chance of F-ing something up. |
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2889 |
Use a GOOD prop puller. The "Iron Man" is a good one. As was mentioned above, keep the prop castle nut on -- just a few threads is all you need. Give the puller plenty of torque. I keep the prop from turning with a block of wood wedged against the trailer cage. Then I go inside and get something to eat. The bang usually comes within 5 minutes or so. Also as mentioned above, a really stubborn prop may need some heat from a propane torch on the propeller hub. This methodology has never let me down. I stay away from whacking the prop so as to protect the transmission.
JQ |
8122pbrainard ![]() Grand Poobah ![]() ![]() Joined: September-14-2006 Location: Three Lakes Wi. Status: Offline Points: 41040 |
Duane, I feel rapping the draw bar is different than whacking it with a hammer to disassemble the spindle. ![]() ![]() |
Page <123 |
