Rudder Maintenance Questions |
davidg
Grand Poobah Joined: January-07-2008 Location: NW Chicagoland Status: Offline Points: 2239 |
Posted: May-29-2018 at 12:56am |
I have the rudder out of the boat to put new packing gland rope in. Does anyone know if the 11A rudder on the boat ('87 Martinique) takes the 3/16 or 1/4 rope? (I think those are the two size packing rope available).
Also, does anybody apply grease, or anti-seize, or anything else when reinstalling the rudder? I have read that some people put grease zurks in to the rudder shaft housing. I don't really want to do that, but, just curious if I should apply something to it to make for easier steering. By the way, when I bought the boat, the steering cable was really stiff. I ended up using the acetone/trans fluid mix to help break the cable free and lubricate it. I let it soak over the winter with the Assa-Trans, and some other lubes. Worked great! The cable moves very easily now. |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2974 |
Per www.skidim.com:
Most Correct Crafts thru 2001 used 3/16" for 1" shafts. |
Dave,
Using some grease is a good idea. |
woodyelc
Senior Member Joined: February-17-2004 Location: orlando Status: Offline Points: 378 |
EPA does not like grease going into the water.
woodyelc
davidg
I hear that, and especially in Wisconsin. Nor do I want to put grease in the water. I have just been confused about whether Correct Craft suggests lubricating the rudder. Zurks, no zurks, grease, anti-seize, etc, etc. |
Then why did CC equip some ports with Zurks? |
I believe the grease zerk ports from cc were o-ring sealed.
Greasing an unsealed port seems unwise to me. |
JoeinNY
Not the same boat but on an early 70s correctcraft with the same 11A rudder that I did this weekend it was 1/4". That boat used 3/16" around the 1" drive shaft. |
davidg
Thanks for all responses.
On the grease....I may put a VERY light coating of marine grade grease on it. TBD. On the rope.....Attached are pics of the rope I pulled out. I couldn't tell what the diameter was. Five rings worth. Joe.....how many rings/windings did you put in?? I thought five were too many. Maybe not. |
Tim, Unsealed, the grease won't last long but what do you feel is unwise about it? It's the same as using plumbers grease on pump or valve stem packing. |
JoeinNY
I took out two mangled threads, put 3 in -
shierh
I used GFO packing for rudder and drive shaft. No need for other lube.
Had a boat years ago that had o ring seals on the rudder shaft, no packing. had to keep it greased. |
davidg
What is a GFO packing? Where do you get it? Also, can the good old fashioned wax rope packing be used for the rudder and drive shaft, or are you guys using the kevlar rope packing? I think my supply store just has the old fashioned wax rope, but, I do recall buying kevlar rope packing years ago from Skidim. |
Jonny Quest
