Impeller Replacement Not Working 03 196 |
shea.95
Newbie Joined: June-07-2018 Location: Charlotte, NC Status: Offline Points: 18 |
Posted: June-09-2018 at 12:14am |
I replaced the impeller on my 2003 Nautique 196. It is a 5.7L Excalibur 330 V-belt. After replacing the impeller the boat is not pulling water in. The engine is over heating. I am wondering if anyone has had this issue and what the solution may be. The impeller is brand new and the belts are all on correctly. Is it a hose sealing issue? Or could it be something else?
Thank you,
Andrew |
Hollywood
Was it pulling before? Bubbles in the strainer?
shea.95
Mine only goes on one way. Yes it was pulling prior to changing the impeller. However, there are no bubbles in the strainer.
Thank you,
Andrew |
quinner
IIRC the V-Belt version of the Excal pump had a recall, do some google searching and you may find more info. My 05' Excal pump may be different, if not it can go on 3 ways and 2 are wrong, as Gary mentioned you need to be sure TOP is on top.
AAM196
Gold Member Joined: October-23-2012 Location: Pittsburgh, PA Status: Offline Points: 846 |
you put your water pump on upside down.
put the water intake hose in a 5 gallon bucket filled with water... you will know immediately if it is on wrong. |
shea.95
So the impeller is working. However, now when the boat is going for awhile the boat loses power and slows to an idle, then will speed up again and die again and so forth. There is no abnormal engine noise or anything. While, there are no squealing belts, the belts do seem loose. I am wondering if this could be the issue. If it is, how do I ensure the belts are tight enough on a v-belt without an auto-tensioner? I am unsure how to pull the pulley's tight enough so the belts are tight.
Thank you,
Andrew |
SNobsessed
There is a PCM manual for 2003 in the reference section. It covers several belt systems. Perhaps this could help you.
Andrew, What did you find was the problem with the cooling? RWP in the wrong position? Why do you feel the belt tension is causing the engine to loose power? |
shea.95
I had not put gasket sealant on the impeller housing so the seal wasn't tight enough to prime the system.
Thinking belts because they feel loose and are the only other part of the boat that was messed with during the impeller change. |
Thank you,
Andrew |
