  New Posts New Posts RSS Feed - Transmission - Problem - Reverse
IUFAN24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IUFAN24 Quote  Post ReplyReply Direct Link To This Post Topic: Transmission - Problem - Reverse
    Posted: July-28-2006 at 9:18am
My 87 Borg-Warner 1:1 goes into reverse but the prop remain stationary. Neutral and Forward work fine, just no reverse. Can there be anything I should look at before I assume it needs a rebuild and start pulling the tranny?
Thanks in advance for help! This board is flippin awesome.
Thankful Do-it-Yourself Wannabe!
GottaSki View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2006 at 9:42am
Disconnect the cable and actuate it by hand. If it still doesn't work, its likely the reverse piston seal. Its time take it out and apart, go all through it, fresh clutches and seals. Its not hard to do.
SKIDIM is good but doesn't have every part you may need. this place is good for mix-a-match
the manual is on-line in the ref section of CCF.com
http://bpi.ebasicpower.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=eBasicPower&Category_Code=ALL3
River Rat to Mole
john33617 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john33617 Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2006 at 2:20pm
reverse plate broke , this kit has everything , you may need new reverse springs also.                             http://www.amarket.com/imabw071.htm
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2006 at 10:24am
john is correct, we see many transmissions with this problem, sea world had this problem often, they would throw the boat into reverse at high speeeds to bring the skier around the front of the boat,and it would break the plates. older borg warners had one plate and decide to go to two plates to try to avoid the proble, it still happens. we use a steel hubbed friction to even make reverse stronger, we also use high graphite plates for forward eric fantasticfinishmarine.com
877-369-6693
