  New Posts New Posts RSS Feed - Engine will not reach max RPM
starbox189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote starbox189 Quote  Post ReplyReply Direct Link To This Post Topic: Engine will not reach max RPM
    Posted: August-05-2018 at 9:38pm
Hello All:
I have a 1981 Southwind with a PCM Ford 351. I recently had water in the engine oil and had new head gaskets installed, heads planed, new exhaust manifolds, new plugs plus other misc new parts. The oil was changed 5 times to clear out the water. The oil looks perfect now. The engine used to max out at around 4400 RPMS. Now it only gets to 3600 RPMs. Timing is 10-11 degrees BTDC at idle, timing, advance is okay, dwell is okay. It sounds great and runs smoothly but won't go past 3600. It has around 450 hrs. The marine mechanic who did the work is a very experienced and I have known him for years. He can't figure it out.
Any thoughts??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2018 at 10:22pm
Sounds like the water got in from the top end??? What readings did your mechanic get from a compression test after the repair?
Post Options Post Options   Thanks (0) Thanks(0)   Quote starbox189 Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2018 at 2:55pm
What should the compression be? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2018 at 4:10pm
The actual reading is not as important as the variance between cylinders. All cylinders should be within 5% for best performance or a max of 10%. Depending on performance level, stock engines run 130 to 200 psi new.
Didn't your mechanic run a compression test?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2018 at 6:47pm
So, same boat, prop, etc. and lost 800 rpm. My first comment would have been to check advance and total timing, sounds like you did that, when you say advance is OK you had a timing light that could read total timing?
If not timing then fuel, might want to get a pressure gauge on the fuel delivery to make sure the pump is putting out enough pressure post rebuild. Also look to see if secondaries are opening fully.
MACS81SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACS81SN Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2018 at 7:14pm
Verify secondaries on carb opening properly. 34-3600 is about where they start opening
1999 -SN - 502 Python
1981 - SN Owned 33 years - Sold
1968 - Mustang - Sold
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2018 at 8:27pm
Agree with Mark.
Was also thinking to check that the throttle cable is allowing the carb to open up to full throttle. A lot of stuff on your top end was taken apart and put together. Throttle cable is an easy thing to pinch or potentially to connect wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote starbox189 Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2018 at 9:04am
Mechanic said he checked compression and it was consistent at 110 psi. Wondering if he just assured me he did to appease me. Anyway, I think I'll check the carburator secondaries, fuel filter and fuel pump next.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2018 at 10:01am
I can see getting 110 since the engine wasn't rebuilt, but would not expect 110 across the board, more of a range than that. Just guessing but seems unlikely it would be that consistent. How many hours are on the engine? Anyway, I don't think compression is your problem so go ahead with the other suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2018 at 12:25pm
Sounds similar to our issue last summer.. I was convinced it was carb related...ended up being the distributor advance. Make sure the plates move freely and that the springs are still good. And of course, also check that the secondaries are opening. You may want to take a look at our thread "New to me 78 Tique"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2018 at 4:25pm
Originally posted by samudj01 samudj01 wrote:
..ended up being the distributor advance. Make sure the plates move freely and that the springs are still good. "
What is the advance your mechanic found or did he just tell you it was "OK"??
