  New Posts New Posts RSS Feed - Prop is off and out for repair...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Topic: Prop is off and out for repair...
    Posted: August-07-2006 at 4:40pm
A chain, BIG screw-driver, rubber mallet and one other person, and the prop popped right off the shaft....
Had a nice chat with Murphy's and they'll turn it in two days.
It's and Ellis 13 X 13 prop by the way. Shop said he doesn't come across many, but indicated it was a good match for the boat.
Should have it back on the boat this weekend, and the hoist properly adjusted so as to not have this problem again!
thanks for the tips.
jeffinohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffinohio Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2006 at 11:07am
they make a tool called a prop puller. i think it will work a little better than your method!
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2006 at 9:27pm
Or if next time it's stuck...heat the prop flanges and then use a big hammer...I had one really stuck...used my prop puller, heat and had to hit it hard with a hammer.
stang
The Super Air
oldskiboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldskiboat Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2006 at 11:44am
Don't heat it to much or you could fry the cutla$$ bearing.
Gary
The Villages Fl.
75Southwind 20
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2006 at 11:55am
Grease the shaft before you put the prop back on. The nut will hold it in place and the waterproof grease will make it MUCH easier to remove again if you have to.
