gt-40 not always starting |
Soulscream
Newbie Joined: August-08-2006 Location: United States Status: Offline Points: 38 |
Posted: August-08-2006 at 12:40am |
Just bought a 1999 air nautique with gt-40 last week. Took it out friday, fired up at home, but wouldnt start at the dock immeadiatly. Turned the key on/off several times and got it to start. Ran around the lake once and the boat was runing perfectly, went back to dock and turned it off, and it wouldnt start. After 5 min or so it started again then started 20-30x without problems. Sinday I went 1/2 day with no problems and then got stuck in the middle of the lake. Towed back to dock when it did start again about 30 min later. Any ideas where to start?? Finally convinced my wife to buy a nice boat and it breaks on the first weekend.....please help.... S.O.S.....
tommer12
Senior Member Joined: February-05-2004 Location: United States Status: Offline Points: 366 |
Sounds like your battery has some bad connections. Check the terminals and make sure they are clean as a whistle and tight. Give the battery a charge and if in doubt, bring it to an autoparts store or marina and have them do a load test on it make sure it is holding. You could also have a stuck solinoid at the starter... cheap part.. but if it happens to not start again when you turn the key (no starter engaging) take a hammer and tap the solnoid to see if the plunger is stuck. If it turns over then, you can probably tell it's the solinoid
JoeinNY
Also check adjustment on the nuetral safety switch and make sure your lanyard is well attached. Probably something simple, most likely the battery connection tommer12 is suggesting.
Atmspltr
Senior Member Joined: May-04-2005 Location: United States Status: Offline Points: 170 |
Sometimes if the timing is too far advanced, the car is difficult to start, particularly when it's hot. Check the timing.
Also check for moisture buildup in the distributor. It would show as condensation in the cap and would only be there after running and would evaporate after sitting a while. |
Soulscream
Thanks for the ideas, guess I should have mentioned that the boat always turns over, just wont fire. This makes me believe that the battery connections are fine. The lanyard also looks good. My best guess is its not getting fuel, this sound correct? Should the fuel pump be on before the motor turns over? All I hear is a click.
tommer12
Oh... it turns over... then its probably not the battery or solenoid. Check the safety lanyard. It's pretty stupid to do this, but the next time you are trying to turn it over and it will not fire, pull the lanyard out and push it back in. I had an OMC outboard do this to me about a month ago. I went all around that engine, even replaced the power pack and it turns out it was just a bad connection at the safety lanyard. Fired up first try.
If the boat has had any moisture build up, the connection to the lanyard could be bad causing it think it's been pulled. They are fairly cheap to replace if you narrow it down to this. |
todicus
Senior Member Joined: July-10-2006 Location: Napa, Ca Status: Offline Points: 493 |
Type in "gt-40" in the quick search location at the top of this thread, and you will find your answer. Just went through the same thing with my 95' gt-40.......... it was a loose and corroded main power line with the in-line fuse located next to the battery.
Good Luck !! |
LakeBoy
Gold Member Joined: July-19-2006 Location: Roseville, CA Status: Offline Points: 709 |
My brother Todicus and I have both been fighting demons in our boats.
I have learned here and other places that many of the GT-40 problems are electrical in nature. They won't tell you this at the dealership. Most of the electrical problems are connection related: bad grounds, corroded connections, etc. My problem was a fuel pump relay connection. If when you click the ignition, before the starter engages, you should here 2-3 seconds of clicking. If you don't hear that, then your fuel pumps are not pressurizing. Tis could be a bad relay or connection. To check the fuel side completely, check all of your filters and screens along the fuel system. I dont' know your model but there was a screen in the tank, at the angle stop coming out of the tank, and at the low pressure fuel pump. Change your fuel cell filter. I read that a fella had a similar problem and replaced his low pressure pump, anmd his problem was fixed (115.00 at skidim.com) Check your connections to the fuel pumps. Check your main wire that comes off the ignition coil. Check all electrical connections. Open them up and inspect. Put a bit of dialectric grease on the connections and reconnect them. Check your grounds. If you can get it to start, work your way around the motor and wiggle all electrical connections. You may find something. |
Soulscream
Well I changed the lanyard switch today, and it didn't work :( I am in contact with a former correct craft service manager, and we did some tests over the phone. He seems to think that the low pressure and high pressure fuel pumps are shot. I am currently only getting a click, and the pumps are not energizing. I will keep the thread updated as parts get replaced, in hopes it will help someone else. BTW if you think the lanyard switch is bad its easy to check by bypassing it with a paper clip, pull the connections off and insert the paper clip.
LakeBoy
Check the electrical connections to the pump. Check the relay. Replace the relay just for kicks. They are cheap and easy to do.
A nautique mechanic told me they have a lot of problems with the low pressure pump. Replace that first. SKIDIM.com has both pumps. 115.00 for the LP and 125.00 for the HP if I remember correctly. Hard to imagine both of them going out at the same time. |
Soulscream
todicus
That is the right one......... you should by two and replace both relays, just to make sure. You have the identical symptoms that I was having on my '95 gt-40. See if you are getting power to your relay with a test light with the ignition on. I would get the clicking, but the pumps would not energize and I had no power to the pumps. I worked backwards from the pump, then relay and found that I was not getting power to one of the relays. Found the problem in the battery compartment.
I replaced the relays I bought reom SkiDim anyway, just so I would have peace of mind. |
Soulscream
The problems was a bad relay to the fuel pump. Thanks for the suggestions everyone. Woot! off to the lake
todicus
Glad to hear you got it working........... the GT-40 EFI's are a little tricky to diagnose. But once you get it running well, what a great motor !!
Have fun at the lake !! |
The Dude
Platinum Member Joined: October-19-2004 Location: Houston Status: Offline Points: 1334 |
Way to go Soul!
Mullet Free since 93
95 Sport |
79nautique
that seems to be one of the most common problems for that motor might be wise to have a couple relay's on hand for future use if it pops up again.
