Budget trailer replacement |
bamajeeps ![]() Groupie ![]() Joined: July-17-2012 Location: Luverne, AL Status: Offline Points: 64 |
![]() ![]() ![]() ![]() ![]() Posted: December-12-2018 at 11:23pm |
I would like to get some ideas/opinions on a trailer replacement for my boat, budget friendly. I have a 2002 Super Air Nautique currently on a Ram-lin trailer built for a 211. It's very rusty. I came across a 90's Ram-lin for a really good price. It was made for a 19.5' Ski Nautique and my boat is 21'. The crash pad can be unbolted and moved forward 13". Possibly for a Sport Nautique?? That theoretically would leave 5" of the boat hanging of the back. Could I possibly extend the tongue 12-18" and move crash pad to correct location to have no hang off? Has anyone done this? Or is it a crazy idea? Thanks in advance for any suggestions.
Is your current trailer falling apart rusty or just fugly? The big problem I see is in moving the boat forward on the trailer you will be increasing your tongue weight. If it's a tandem and not moving the axles forward wouldn't the axle in front be caring a higher load? The other problem I see and others will know is a SN a different hull than a SAN and not fit ?
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13522 |
Poor idea
Current trailer is falling apart. Right now it has no tongue weight, under 100 lbs. Trailer I'm looking at is a single axle and boat is a v-drive, so more weight in the rear. I was hoping that moving it forward it might equal out the weight. |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21198 |
+1 |
desertskier ![]() Platinum Member ![]() ![]() Joined: December-19-2006 Location: Az Status: Offline Points: 1117 |
My CC trailer is rotted out so I have been looking also. I recently purchased a trailer from a 2013 Carbon Pro for $600 that has a lot of surface rust but will work until I come up with a better solution. Keep an eye on ski-it-again. That's where I found mine. If you find an early Ramlin or CC make sure you look inside the main tubes for rust. They look fine on the outside but are rusting from the inside out. Mine went from looking great to toast in a couple of years and that's in Arizona.
may work |
To clarify, it’s rhe use of a dd trailer for a vdrive that is the poor idea.
RLXI trailer linked above is also dd. |
Thanks for the information. I'll keep an eye on Ski-it-again |
Thanks for the clarification. I understand that it's not the best idea or safest. I am curious if anyone knows the difference in location of the axle on a Ram-lin single axle trailer. |
rosconole ![]() Gold Member ![]() ![]() Joined: May-10-2008 Location: United States Status: Offline Points: 760 |
No such thing as budget and trailer that go together
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
Thanks for your $.02, so helpful. |
rebel skier ![]() Gold Member ![]() ![]() Joined: October-17-2014 Location: Middle Tenn Status: Offline Points: 777 |
Check out Orlando76's thread about his trailer. Ramlin will re-furb your trailer. I am thinking about bringing mine there, it is just a matter of when.
