Interesting wear on prop |
Author | ||
cgerdz ![]() Newbie ![]() Joined: July-01-2019 Location: IL Status: Offline Points: 23 |
![]() ![]() ![]() ![]() ![]() Posted: July-30-2019 at 12:58am |
Haven't seen wear like this before. Acme 422. When does this type of thing become a structural integrity issue?
gt40KS ![]() Gold Member ![]() ![]() Joined: August-05-2017 Location: Wichita Kansas Status: Offline Points: 946 |
Interesting, and puzzling. It looks like a type of corrosion.
JCCI
1995 Ski Nautique GT40 |
Google Cavitation-corrosion. It is particular form of erosion caused by the "implosion" of gas bubbles on a metal surface. It is often associated with sudden variations in pressure related to the hydrodynamic parameters of the fluid (e.g. hydraulic turbine blades, propellors, stirrer blades, etc.).
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11191 |
Is it the same on all 4 blades?
Yes, it is essentially the same on all 4 blades.
I think a better picture would be good showing the pitting/erosion better.......with no shadows right in the affected area
![]() Then send the same picture and question to Acme and see what they say How many hours of use on the prop? |
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3009 |
It looks like cavitation erosion to me. My company's ocean-going vessels have to replace propeller blades on a planned schedule -- due to cavitation erosion.
Erosion due to running in low water / silt conditions looks different....the blades are thinned out and shiny. |
The rash on props isn't uncommon. I've seen it more on older hand worked cast props. Here's one from the past:
Seems like your picture and his show the issue in two totally different locations Pete
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13521 |
Well, it’s on the blades and symmetrical isn’t it?
Yes, it seems you are very observant today. |
Sharp as a bowling ball ![]() Still waiting for some better pictures of your modified prop Pete |
Once upon a time a short time ago in a land call the USA, there was a company called Central Valley Propeller. (CVP props for short)
They were pretty popular They turned into a company that no longer exists, because a number of their props came apart right where the blade meets the hub launching a blade right off the prop. They had thin blades, so do Acme props Same area as cgerdz prop which is a little different situation than Pete.s prop picture from a Ski Supreme thread I figure Acme may want to get an upclose and personal look at his prop |
Looks just like this on all 4 blades
Now that's a good picture ![]() I'd be talking to Acme |
You're probably right about Acme wanting to take a look. I'll get in touch with them next week.
I have no idea how many hours are on the prop, I'm at least the fourth owner of the boat, and the prop came in a box as a spare. I got it at 452 hours right before the 4th, and we hit 477 today. I'd bet almost anything this is bhectus old boat (unless there is another with an Apex, the exact gel scheme, and N3 guide post covers on it), doesn't look like he's around the forums any more though. |
Does the trailer have clear plastic crash pads?
Sure does.
