Ski Pylon wanted |
blueridgespeed ![]() Newbie ![]() Joined: July-21-2019 Location: Alexander NC Status: Offline Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: August-05-2019 at 11:36am |
So, I'll be doing some work to install whatever pylon I can find (or make). I have a 1979 Southwind 20
The "hole in the floor" is there (patched with plywood) and a sump is currently occupying the bilge-front "socket" in the keel. I would consider a "skylon" type of taller pylon as well - understanding that these types require a set of support lines to a bow-ring strap or similar. Located in NC zip 28701 |
NCH20SKIER ![]() Grand Poobah ![]() ![]() Joined: December-16-2004 Location: United States Status: Offline Points: 2214 |
If you are looking for a ring and finger pylon I have one
Located on Badin Lake Zip 28127 |
'88 BFN |
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13523 |
Southwind pylon will likely be a little tougher to find.
The floor is further from the hull, influencing where the bend is. |
Thank you - and thank you Hollywood.
If we can measure the available pylon - I can measure my boat. The Southwind has a taller freeboard - the Barefoot somewhat shorter, and then most nautiques even shorter - by appearances. It follows that the floor-to-hull keel distances correspond. Hollywood - I did not realize the pylons had a "bend" Are you referring to the area of taper from a larger diameter down to a slightly narrower diameter at the base of the ring? |
Stolen picture from TRBenj showing pylon bends-
