  New Posts New Posts RSS Feed - Hard steering on 93 sport nautique
Slalom fan 4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Topic: Hard steering on 93 sport nautique
    Posted: May-10-2020 at 11:13am
I bought a 1993 sport nautique from a local dealer. Being as I live 120 miles from dealer and drive long haul truck I had to break the first rule of buying a used boat by not sea testing. I did run it and check every thing else and all seemed good however when I got her home to local lake I found the steering was super hard at speed especially to the right. Dealer said it's supposed to be a little stiff and probably not cable as it's only when at speed. They said bring her back and the will check. I've driven both 92 malibu and 04 moomba as well as read many posts here and stiff is the last thing steering should be. Any thoughts?
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 1:10pm
I guess it depends on what you mean by stiff. Because of the direction of the prop rotation the boat will always want to go to port. So it takes more force to turn to starboard. You said you don't think it needs a cable. When it's on the trailer you should be able to spin the wheel with one finger.
92 SN - Owned since 93
99 Pro Air
89 SN - Went to live on a lake in Texas
75 Donzi 16 - Sold in 93
rolleronariver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolleronariver Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 1:43pm
I have a 92 sport that had the same issue. I replaced the cable and repacked the rudder shaft and greased everything really good. It helped a ton. Still a little harder than I expected but not bad at all.
92 Sport nautique
80tiquefan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 80tiquefan Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 2:59pm
I have a 93 Sport Nautique and I recently upgraded my steering cable. I would recommend changing the steering cable and go ahead and upgrade to the newer cable and helm. The cable change and upgrade on these boats are super simple. I would also recommend repacking the rudder packing gland. There is also a grease fitting on the 93 sport's rudder which makes it easy to grease in the future.
Jason Murray
1980SkiNautique
1993 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 3:23pm
Originally posted by desertskier desertskier wrote:
I guess it depends on what you mean by stiff. Because of the direction of the prop rotation the boat will always want to go to port. So it takes more force to turn to starboard. .
Plus 1
Rodney,
What was your previous boat(s)? Were they inboards?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 7:16pm
Stiff is an understatement it's more like dangerously hard. I've driven 5 other boats in m my life 3 i/o and 2 inboard and none were anywhere near this hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolleronariver Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 7:18pm
You need to replace the cable and maybe helm if it’s that hard. Mine was nowhere close to that hard when I replaced it.
92 Sport nautique
jimsport93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 7:46pm
Bought my 93 Sport in 2007
Steering was pretty tight. Became even harder to turn. Eventually had to use two hands.
Replaced the cable. All is good. Smooth and easy.
Back then it was just the cable. Think you have to do cable and helm now. As they don’t make that particular sized cable (where it connects to the helm) any longer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 8:19pm
That seems to the consensus here that and rudder repack and grease. I kinda get what dealer said about if it was cable it would be hard when trailers as well but will see what they say next week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 8:25pm
If dealer doesn't fix it I will do all of these.. thanks for the tips.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolleronariver Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 10:46pm
That’s the beauty of this site. I’ve owned our Nautique for 4 years now and this site has saved me more money and time than I could ever count. There is a search function on here but sometimes it’s easier to search the site via google. Congrats on the boat. We love our sport.
92 Sport nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 11:31pm
Not true. It will be the cable. The lube in the cable dries out and gets gummy, I cut open the cable in my 69 the only problem it had was that every winter it froze so I knew it had water in it. Sheath was damaged but it always worked. The other 2 cables were an 94 and a 95. I think they use a different lubricant in later ones because when I cut them open they were gummy. Both went bad over their storage season.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 11:55pm
+4
Replace the cable....and while you are at it, you can properly lube everything up.
If you get a lot of water in your bilge, that can contribute to premature cable failure. The voice of experience here...
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2020 at 11:24am
Steering, gear shift, throttle are pretty important safety items. IMO it is worth $300 to have it optimum. But it ain't my money so what do I know . . .
