  New Posts New Posts RSS Feed - Bent prop and tracking fin
MurphyCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MurphyCO Quote  Post ReplyReply Direct Link To This Post Topic: Bent prop and tracking fin
    Posted: June-22-2020 at 7:48pm
Unfortunately we dead -centered a mostly submerged tree last week in our 1999 GT 40 - Air.
We weren't hurt, and it appears the damage is a bent first tracking fin (I think those are called) and of course the prop is modified now (bent pretty good).
We were able to limp home (several miles in a pretty bad storm) got soaked, but the boat would make about 5 MPH without shaking badly. We have a covered dock and lift so we have the boat safely secured.
I believe the prop is an ACME 422 so I ordered one. I believe from just rotating the shaft that it is not bent, seems very true and smooth.
My question is about the bent 1st tracking fin; the 2nd and 3rd one are fine, the first one took the brunt of the hit. It almost looks like I could straighten it with angle irons and clamps, but I thought I would ask this group. I was hoping to replace the prop on the lift so I don't have to pull the boat, but if I need to address the fin, seal it back, etc., I would need to pull the boat.
Any advice? Where could I purchase a fin?
Thanks,
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2020 at 7:54pm
Gary,
Tracking fins can be straightened but that depends on how badly bent it is. I'd say the best way is to remove it so it can go into a hydraulic press. For new ones, click on the Nautique Parts banner above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MurphyCO Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2020 at 8:06pm
Thanks, I ordered a new fin. Seems like less trouble and July 4th is fast approaching.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote MurphyCO Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2020 at 10:54am
Gary,
Are the tracking fins just bolted to a plate that doesn't require re-sealing? Any thru-hull consideration?
Thanks again.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2020 at 11:01am
The base and screws should be sealed to the hull. I suggest 3M 4200.
flyweed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flyweed Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2020 at 2:29pm
Agreed with Pete....be sure when putting on the new fin to use the 4200 to seal it up water tight.
Drink Tonight..for tomorrow We Ride!
AAM196 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2020 at 3:42pm
Hey Gary,
3 years ago I was in a gosh darn hurry loading my boat on my Eagle (raised bunk) trailer... I was coming in hot and slightly off center and bumped my lead fin on the bunk and knocked the fin clear off... I recovered the fin and screws from the water and fixed it once I got home. I couldn't believe the fin came off as easy as it did as it wasn't much of a bump... but now that I think about it... I'd rather the fins pop off than sustaining any serious fiberglass damage if I hit something...
I can't remember if I had to straighten it or not but it is brass and easy to do! There wasn't really any damage to the hull but it stripped the screw holes... to fix:
-clean all the sealant off best you can..
-if screw holes are stripped even the slightest... fill with a little marine/fiberglass epoxy
-drill pilot holes in the new fully cured epoxy.
-clean surface again with rubbing alcohol... apply your 3m4200 on base of fin and screw back into place...
check the other fins while you are down there.
You should be able to do it all while on your lift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MurphyCO Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2020 at 6:51pm
Thanks for all the replies! Gathered up a new prop and a new tracking fin and will replace them this weekend. I'm going to pull the boat just so I don't drop anything in the water....been known to do that.
Thanks again,
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote MurphyCO Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2020 at 4:24pm
Thanks to everyone for their input. Turns out the bent tracking fin was damaged last year hauling out the boat at the end of the season. The marina ramp was congested and the angle was bad so I clipped the fin on the bunk coming in. It's now replaced.
ACME 422 prop installed, and my only struggle was removing the bent one without a prop puller. (I was certain my 6" gear puller would work, but it did not). I was able to borrow one from the marina owner and other than the loud explosion when the old prop came off (I was warned this would happen) it was a simple matter to change out. Those ACME prop pullers are definitely worth the money.
Thanks again, we're ready for the 4th!
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2020 at 4:41pm
Gary,
Hopefully you lapped the new prop to the shaft.
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2020 at 9:04pm
Thumbs up on the lapping.
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2020 at 11:08pm
I will one up you. Two thumbs up on lapping.
