Trailer Bunk Carpet |
TG3
Senior Member Joined: May-29-2020 Location: Tyler, Texas Status: Offline Points: 106 |
Posted: March-09-2021 at 10:39am |
My trailer needs new bunk carpet, the previous owner installed something cheap and it is worn through already (one year old).
What is the best stuff to use? I see different weights for sale, from 12oz to "heavy duty" 16 oz. Is there a brand y'all prefer? I found some on Amazon made by CE Smith that has a 16.1oz weight and pile thickness of 5/32" and claims "heavy duty".
1997 Air/Sport Nautique
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2978 |
I used bunk carpet from Dorsett Industries and Foss Mfg when I re-carpeted the bunks. My local marine supply shop had it in stock. Just ensure that it is designed for trailer bunks and you should be OK.
Nautiquehunter
Platinum Member Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
If you load with a shallow trailer position you will shorten the life of the bunk carpet. Sinking the trailer and floating the boat most of the way puts less wear on the bunks. It also makes it harder to line up and center the boat on the trailer.
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1750 |
My 93 Ramlin/Nautique trailer had two strips of carpet on the top edge of the bunk.
Did the same when I replaced mine a couple of years ago.
TG3
Thanks for the responses! Being new to this boat, I have been loading it by powering it up the bunks. My old I/O was a small, lighter boat and was easily loaded this way. I am going to learn differently this season and sink the trailer and float on as Michael suggested.
As a side note, I am considering converting my trailer that has a bow roller to a have bow stops, Ramlin style. That looks like it will help with alignment when floating on.
