  New Posts New Posts RSS Feed - Trailer hub grease fittings
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Topic: Trailer hub grease fittings
    Posted: April-29-2021 at 1:57pm
The small-ish fittings on my hubs will pop out when removing the press-on style of grease gun. Ok to over size the fitting?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2021 at 9:41pm
How about installing a set of Bearing Buddy wheel bearing protectors?  Some are nay-sayers on Bearing Buddy, but they've never let me down yet.
https://www.bearingbuddy.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2021 at 5:50am
I can't decide whether you're saying that the grease fitting pops out of it's threads or something else.
If that's the case a grease fitting with bigger threads seems workable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2021 at 7:07am
Drive in or as mentioned "press in" Zerk fitting will pop out.
Threaded is certainly a better option but I'd say disassembly to keep metal drillings and tappings out of the grease is best. Using the old "grease on the tap" trick is too risky.
Mark,
Try a new drive in Zerk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2021 at 9:47am
Mark,
Yeah, the Zerz is coming off with the gun. I'll get the next size up Zerk drive-in. That should do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2021 at 9:51am
Mark,
[/QUOTE]
The next size up requires drilling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2021 at 10:01am
Ahhh...ok. Well, I'm picking up the boat in the next week or so. I was going to change hubs, but I think I'll pull them off, inspect, replace what is needed, if anything, and put back. Easy enough to drill or tap for either a press or threaded Zerk, at that time.
