  New Posts New Posts RSS Feed - 92 SN Fuel Sending Unit Replacement
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Topic: 92 SN Fuel Sending Unit Replacement
    Posted: June-22-2021 at 10:43am
I just replaced the fuel sending unit on my '92 so I thought I would post the information for others who may want to do the same.  The original sending unit just caused the gauge needle to bounce all the time and never gave an accurate reading.  I knew it was getting low on fuel when it stopped bouncing.  The replacement causes the needle to move up and down a little but is basically very stable and looks to be accurate.
The tank depth measured 11.5" so per the KUS website instructions for a plastic tank I ordered a 10.5".
The units are available from multiple sources NP, Amazon, Ebay, marine supply stores etc..  I made sure to get a genuine KUS unit.
It was pretty easy to install.  Removed the back seat then disconnected the tank straps and pulled the tank forward on the passenger side at an angle until the sending unit was clear.  Then swapped the units and connected the two wires.
92 SN - Owned since 93
99 Pro Air
89 SN - Went to live on a lake in Texas
75 Donzi 16 - Sold in 93
