Odd starting issue |
Netdewt
Senior Member Joined: February-15-2010 Location: Minneapolis Status: Offline Points: 215 |
Posted: July-03-2021 at 6:56pm |
I’m not quite sure how to explain this. It happened once a day over the last 2 days.
Last fall I had my pitot gauges replaced with Faria GPS. I’ve also recently replaced the thing the key goes into, ignition key thing. So what it does is I push the ignition switch, then turn the key as usual. It turns over fine but doesn’t start, and the starter continues to turn and turn and turn, even though I am not holding the key on. I pull the key totally out and turn off the ignition switch, and it kept turning over. It stopped when I put the key back in and turned to on position. Clearly there is some kind of short. Where should I even start though? 1989 SN 351W |
1989 Ski Nautique 2001, 880 hours
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10889 |
Does this happen every time or just sometimes, couldn't decide from the description if it got started 10 times a day for example and acted up once or you started it once and had the problem. If you look at the back you should have 3 terminals unless you bought one with an accessory position, then there will be 4 terminals. If you look at the TRB diagram below which works very well for your 89, you see a Red wire that should go to the BATT terminal, a Purple wire attached to the I or Ignition terminal and a Yellow/Red wire attached to the S or Start solenoid terminal. I'd make sure you can read the terminal markings and that the right wires are on the right terminals. Alternately, I think maybe it's the "Revenge of the Airguides" |
Netdewt
I’ve been starting it probably 20-30 times a day as we are out and getting kids going. So it’s not every time at all.
Yeah I would have loved to keep the air guides. They are haunting me. |
Well in that case, I'd replace the starter solenoid/relay on the back of the engine and make sure it's grounded good through the mounting bolts.
It sounds like the big internal contacts are getting bad and stick and one time will weld themselves together. It's probably working with the ghost of the Airguides
Netdewt
Thank you, that gives me a “starting” point.
