  New Posts New Posts RSS Feed - 79 ski nautique stringer replacement
 Post Reply Post Reply Page    <12
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2022 at 7:41am
The above makes sense… unless you’ve actually gone through the process.
Consider that the OMC mounts you have are not only inferior to the PCM’s, but parts for them (namely rubber isolators, etc) are NLA. If you tune your stringer height to accomodate the shorter mounts and someday have to swap them out, the taller PCM’s won’t fit unless you have the extra height to give. The factory configuration that accommodated both may be the wiser choice.
John
Those mounts are readily available through lots of places. Not parts, but the whole mount, nothing rebuildable (and pretty reasonably priced).
I think yours are Commander since  they say Commander on them  Wink
A whole bunch of marine engine companies use those style mounts
I don't know if this will affect your plans on the blocks vs changing the stringer height, but whichever way you go, it's good to know the mounts are readily available if you need them
As far as their "inferiority" maybe someone will explain that comment
PS Your stringer dimensions are all shown in millimeters not centimeters like you used earlier unless you're building a really big boat Wink
