  New Posts New Posts RSS Feed - Ever wonder what a GT40 weighs
jhersey29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Topic: Ever wonder what a GT40 weighs
    Posted: March-23-2022 at 5:01pm
833ish lbs. with transmission.  No oil other than remnants from drains.  The stand and 2 pieces of 2x4 don't weigh all that much.  Missing a few water hoses.
833.5
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: March-23-2022 at 7:17pm
Would make sense to go all aluminum in a rebuild if you had a trashed block I suppose. If also you went aluminum heads, intake and exhaust, I'd imagine a couple hundred lbs of weight savings, maybe. If light weight is important, and money isn't...there you go. I'd imagine someone has done this...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: March-23-2022 at 7:36pm
Someone has indeed...
With help from my friends at Edelbrock, I replaced:
Heads
Intake
and scored a pair of
Pyramidal exhaust manifolds...
...all in aluminum.
I also
Converted to a crank-driven RWP,
and an aluminum PCM 40a transmission.
Misc and Sundry
and a 26 ib. battery.
Net saving was @280#
Did nothing for performance or wakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: March-23-2022 at 7:56pm
NICE!
See, I knew it.
You’re getting the best gas mileage than any of us! Easily break even on cost in a couple of ge stations;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: March-23-2022 at 8:32pm
Heads
Intake
...all in aluminum.
I also
Misc and Sundry
But now you can respond to the “unwashed masses” of cast iron engine components with an air of gravitational superiority.
Which is nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 2:58am
MorningWood,  I need to ask what power difference you found with the new heads and intake.  Does it run out at a faster top speed, what RPM before and after.   Sounds like a fun toy now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 7:19am
833.5
Sounds like a good number to me.Wink
PCM listed a weight of 856 ish pounds in their 89 PCM engine manual with most likely a B/W transmission pictured in the manual and the older heavier starter. A little difference in carburetor and fuel injection components also.
Throw in a little difference between scales and the numbers agree pretty well.
Here's a link to M/W's old thread on weight savings and there's also a link to the PCM manual from 89 that gives some other engine weights too, (see chart on page 15)
link to PCM manual
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 7:34am
More important is...What's under the cover on the Triton Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 9:19am
2017 Skidoo Summit X 850 w 165 track and 3” paddles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 10:12am
Nice!!
 I just got back from riding in Wyoming. I ride a 154 Freeride
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 10:54am
We ride mostly in Colorado.  Vail Pass, Wolf Creek, Rabbit Ears, Jones Pass, Tabernash, Buffalo Pass, etc.  If you end up out this way hit me up.  Always looking for people to ride with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 12:29pm
Damn!  Y'all are just KILLING ME!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 7:48pm
Great Pics of the snow, Thanks.   I rode that area above Vail twice with a buddy.   Very incredible terrain.
The new machines ride so well and have such power it is hard to imagine unless you have done it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2022 at 9:36pm
The details listed above, and the resulting performance, did nothing for the '81 SN that I built it for. (the original goal there was to improve the wakes while adding some power). It was an honest 50 mph boat.
I then transplanted that powertrain into the '82 SN (Cyndi) that I have, and sold the '81.
As for the '82, the performance was increased substantially...subjectively. This being the 5th 2001 I've owned, it is clearly the best performing-powerwise. Over 50 mph...(GPS)
So now working up the '94. I robbed the heads and intake (Edelbrock Performer series) and exhaust manifolds from the '82 and gave her the GT-40 heads from the '94. I've reworked the crank-driven cooling system a bit,  but have yet to drive the '94 to report. Stay tuned...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2022 at 12:12am
Ready to catch the updates!  I have been tempted to modify my GT40 for more power but they I take it out and it runs so good I just can't justify tearing it apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2022 at 6:04am
Myself, I'd probably wonder more about why the engine is hanging there to begin with
I'm thinking it's undergoing some gender transformation and turning into a Chevy  Wink
