Probably another swim platform refinish thread |
RealDeez
Senior Member Joined: August-01-2019 Location: MI/IN Status: Offline Points: 130 |
Posted: April-13-2022 at 2:52pm |
Previous owner of our 93 sport appears to have attempted to put polyurethane on the swim platform... which I will now have to attempt to finish removing. Nature got a pretty good start on the removal though. I guess I don't blame him because if I hadn't started reading threads about it here I might have attempted to put poly on it... I have coarse and medium sandpaper and assorted wire brushes ready. Teak oil on standby. We'll see how it goes. |
Lake James, IN
93 Sport Nautique |
RealDeez
I know it's not recommended to sand but I took a pass on a small area with the wire brush and I couldn't tell if it was coming off and exposing clean wood or if it was melting the poly down and grinding it into the pores... I guess I could try stripping it but I was trying to avoid chemicals because of ventilation and cleanup issues. |
Lake James, IN
93 Sport Nautique |
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1115 |
I use sandpaper. Never heard that you shouldn't. Sometimes I use it to rub in the teak oil. I think I got that idea from an old platform refinish thread. It works well.
92 SN - Owned since 93
99 Pro Air 89 SN - Went to live on a lake in Texas 75 Donzi 16 - Sold in 93 |
desertskier
Have you tried a power washer?
RealDeez
Do you think it would strip the poly off?
Because I would need to buy one to test that theory. |
Lake James, IN
93 Sport Nautique |
desertskier
It would take it off but it might damage the wood.
RealDeez
Could turn into an expensive experiment at that rate...
Lake James, IN
93 Sport Nautique |
desertskier
I use a pressure washer on mine every time I refinish it but just to clean it. If you had one you could try a spot underneath and see if it worked but I don't think I would buy one just for that. Although, it might be a good excuse to buy one anyway.
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2207 |
Apply some citrus stripper and let it do its thing. Hit it with a wire brush (with the grain and repeat)
As you get to the point you are satisfied with the appearance ditch the wire brush for a stiff bristle nylon brush Rinse well and often to keep the crud off the clean wood as you are working I would then apply a teak cleaner / conditioner and move to the teak oil (TSP from the Home Depot or Lowes also works) Everybody has a method and many will share - this has worked well for me in the past Good Luck |
'88 BFN |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3734 |
I have a 4” belt sander with about a 12” footprint while sanding. I have used it with a medium grit a few times over the years on my old boats and once on my 95 Nautique when I want to get my rear deck back to looking new. You have to move constantly. If you hold still for any time it will dig an area that takes forever to sand out. It would burn up one or two belts taking off your poly. I don’t fine sand when I finish, I like the deck to be non slip. The belt sander can remove a lot of material pretty quick so again, be careful, keep it moving and this is not a technique to use every year as it takes off a lot of material. This is used to bring one back from the dead.
RealDeez
Wire wheel on the drill and a 1/4 sheet sander with some 60/100 grit later.... Wheel took off the poly shell, sander cleaned up. Did they put poly underneath? Yes, yes they did. |
Lake James, IN
93 Sport Nautique |
RealDeez
So, I'm not going to show the bottom again because my zeal for making that look good waned quickly... But I took the Starbrite and wire brushes to the platform and here is the result... That's while it's still wet. There is still some poly in the cracks that I can't decide if I want to risk the tendonitis to remove. I figure once I oil it and run it around for the season the poly will sort of... remove itself but I could be wrong. |
Lake James, IN
93 Sport Nautique |
RealDeez
Here it is dry-ish. So I'm trying to decide if I really need to go after the remaining dark-ish spots with the Starbrite again or if it's good enough to oil up as-is. Thoughts? |
Lake James, IN
93 Sport Nautique |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2943 |
Good to go in my opinion. I like the Star Brite Teak Oil. May bueno.
Mpost
Senior Member Joined: July-05-2018 Location: Monticello, MN Status: Offline Points: 329 |
When I did my 84 SN platform years ago, I completely dismantled the platform. All the screws out and pieces separated and sanded it that way. I even ran it thru a surface planer to get the multiple layers of Poly/? coatings off without taking too much wood.
Turned out very nice and coated with couple of coats of teak oil before reassembly. That platform had wider gaps between boards than yours. Was a lot of work but a good winter project. Yours looks very nice right now and will really be nice with multiple coats of oil. Too many coats and it will be dangerous slippery, made that mistake a couple of years ago on the 98 SN
84 SN Sold 98 SN Lund Pro V 1975 Alumacraft
MrMcD
It is looking great, your work is paying off.
wayoutthere
Senior Member Joined: February-28-2020 Location: Florida Status: Offline Points: 416 |
The dark spots add character, that's a beautiful piece of wood.
Great job on that.
gun-driver
https://www.homedepot.com/p/3M-Pro-Grade-Precision-2-7-8-in-x-4-1-2-in-x-1-in-80-Grit-Medium-Dual-Angle-Edge-Detailing-Sanding-Sponge-24300PGP-M-DA/205416027?ITC=AUC-133407-23-12070
One of these will get the poly out of the cracks.
RealDeez
Well, I went and put on some oil... Still pretty wet. I'll see how it looks in the morning but I think it'll be fine the way it is. |
Lake James, IN
93 Sport Nautique |
