  New Posts New Posts RSS Feed - Raw water pump replacement
Ryan78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan78 Quote  Post ReplyReply Direct Link To This Post Topic: Raw water pump replacement
    Posted: July-14-2022 at 12:30pm
Hello. I am wondering if anyone can help me. We have a 1978 ski tique that needs the plastic raw water pump housing replaced. It is a Jabsco 17410-0001. I found one and it broke in half. Unfortunately Jabsco is back ordered for 6 weeks. Does anyone know where I can find another? Any help is appreciated. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2022 at 1:24pm
Are you wanting to replace the housing, or the whole pump?
People have replaced the Jabsco with a Sherwood G21 type pump without much in the way of modifications or there's a DJ raw water pump that's from South Korea that's a copy of the Sherwood that would work too.
I imagine since it's summer, you want something right now that'll get you on the water Wink
Does yours mount to a stamped steel bracket like this one?
If so, people cut the end of the bracket so that the Sherwood or DJ pump with a pressed on pulley can be easily installed
Your Jabsco has a set screw and key holding the pulley in place so it's easy to remove from the bracket, but I figure you already know that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan78 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2022 at 3:32pm
Thank you for the reply. I was hoping to replace just the plastic housing if possible. I just can’t seem to locate one. And yes mine is the same bracket.
