Random transmission/engine problem SN2016 |
Tosse ![]() Newbie ![]() Joined: September-21-2016 Location: Sweden Status: Offline Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: August-30-2022 at 10:12am |
Hi, we have problem at the Ski Club. Sometimes (about 1 of 30 starts) the transmission during start of a skier just goes into neutral for about a second. Most of the times we manage to throttle down, if we don't it goes into gear again quite abruptly. When throttled down, the engine still runs and a new start will go just fine. This can happen once every week or sometimes several times on one day, completely random. • Last season the neutral switch on the throttle control failed, we then exchanged the throttle control box for a new one, the problem above then disappeared as well as the faulty neutral switch. The above problem just reappeared after more than half a year , neutral switch still works OK. • Boat SN200 2016, PCM 5.3 • Runs at Water Ski club in Sweden, we will still run until the water temp is about 10–15°C (59-59°F) • Oil levels ok (engine 5W30, Transmission Dexron III) • Runs at ski club, so about 10 different drivers. • Seems to be somewhat related to heavier skiers/harder starts but it have happened with light starts but more unusual Any ideas would be greatly appreciated!
Ski Nautique 1974, restoration in progress...
FFImarine ![]() Senior Member ![]() Joined: June-21-2016 Location: Medina Status: Offline Points: 149 |
Is the trans a electric shift?
You break it I’ll fix it
