Change entire fuel water filter bracket? |
seacamper
Platinum Member Joined: June-24-2010 Location: Florida Status: Offline Points: 1056 |
Posted: December-16-2022 at 9:03pm |
Hey Guys,
Is it sacrilege to swap out the large fuel water separator on an 86 SN with this: I am just thinking that my kids would be more likely to swap out something they can get off the shelf at West Marine. I know I did this on an Osco 351 in a narrow body because it came with a weird WIX gas only filter, and it worked fine.
1980 Ski Nautique Boat Bar
1988 Mastercraft Tristar Open Bow 1988 Mastercraft Tristar Closed Bow 1969 Seacamper Houseboat 1986 Harris Pontoon 2004 Seadoo GTX SC + Flydive Xboard 1999 Adventurecraft |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10645 |
I'd swap that thing out in a heartbeat and throw the original away or sell/give it to one of those "keep it original types" that might actually think it's a sacrilege
pjsmoreno
Senior Member Joined: April-25-2016 Location: Liberty, Mo Status: Offline Points: 161 |
I would change
it out due to the bulkiness, hard to change out without spilling gas let along
getting the casing off the bracket to get to that filter. But like Keno said, people like me like to
stay original. Not a priority for me now but the day will come. |
mrhemi
Newbie Joined: September-02-2009 Location: Canada Status: Offline Points: 28 |
I have recently changed the one on my '89 to that style (as part of my "barn find" refurbishment that I will be updating in a previous thread). I utilized the original bracket so you actually have to look close to see it has been altered.
Interesting thing, I was the original private owner of an '83 Ski Nautique that was equipped with a Mercruiser 350 GM engine. It was fitted with that type of fuel / water separator as well as a much handier remote oil filter setup. On those two items, Mercruiser was way ahead of Pleasurecraft. Not so much on others, raw water pump and ignition being two big problem items on the Mercruiser.
You know you are getting to be vintage when someone says "Back in the day..." and you can dispute their facts.
Mr. Mike. |
seacamper
Thanks guys. It is done. Pretty easy job. I used the old bracket. West Marine sure has come down on it's prices. They actually had it on the shelf.
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1114 |
Sounds like a good idea. Any pictures?
92 SN - Owned since 93
99 Pro Air 89 SN - Went to live on a lake in Texas 75 Donzi 16 - Sold in 93 |
AZ86SKI
Senior Member Joined: July-05-2022 Location: Phoenix, AZ Status: Offline Points: 115 |
I will post some photos of how mine was done with the original bracket when we get through the "No posting photos zone" that we are experiencing as KENO described. |
andrewmarani
Senior Member Joined: May-31-2005 Location: Baltimore, MD Status: Offline Points: 212 |
Good post. I really dislike the old water separator so this change is happening as I rebuild my 1986.
Builder
seacamper
Let me know when I can post pics. We went with 3/8 fittings, so we just used 90* elbows like the old one had and 3/8 nipples. If we had gone with a 1/4 threaded filter, we could have used the old ones, and sadly we finally ground the 90* bracket off to make it a straight bracket, and drilled 2 holes for the fuel filter bracket.
I was going to keep the 90* overhang, so it was still original, but my son rolled his eyes at me.
AZ86SKI
brhillman
Groupie Joined: August-01-2021 Location: Snohomish WA Status: Offline Points: 62 |
andrewmarani
Nice job on the bracket.
In the picture, it looks like you skipped the original black plastic carpet transition piece between the floor and the side carpet. I like your look much better, any issues with not having the transition strip? Which did you put down first, the floor or the side carpet?
Thanks |
Builder
brhillman
The black plastic is actually there, just not that visible in the photo I think because of the angle and focus. I do think I’ve seen it skipped in replacement installs before, but can’t comment on how that would work!
