  New Posts New Posts RSS Feed - Boat lift support
Boat lift support
359 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 359 Quote  Post ReplyReply Direct Link To This Post Topic: Boat lift support
    Posted: June-24-2023 at 5:41pm
This might be a dopey question, but I have a used Shore Station for my SN 2001. It has the old style flip flop supports on it, and the previous lift owner screwed 4x6 beams to the supports from front to rear. My boat fits fine, but those beams are so buoyant that the cradle floats and makes loading the boat a little tricky. Will it hurt my boat to take those 4x6s off and just use those 4 floppy pads to hold the boat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2023 at 7:02am
Why don't you try something with half the buoyancy like 2x6 beams for example?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2023 at 2:25pm
We had a similar problem with the lift floating because a full keel boat needed the height on the bunks to clear. Our solution was to attach 3" pvc filled with cement
Mpost View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2023 at 2:38pm
I put a seet of these on my lift a few years ago. didnt want to deal with wood and carpet again. Most every manufacturer makes these for lifts. Alumn. with rubber-ish blue on top.
Wow, Cant believe this picture upload actually worked today ????
84 SN Sold   98 SN    Lund Pro V   1975 Alumacraft
359 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 359 Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2023 at 5:36pm
I thought about that, but my lift is in a shallow area and I would rather have the cradle just sink all the way down and keep tension on the cable.
I also considered adding weights, but my lift is rated for 2600 lbs (4000lb winch though, I don't get it) but I dont want to max out my lift or make it harder to raise out of the water when I leave for home.
Mpost, that would not be a bad idea. I'll have to look into that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2023 at 6:23am
I just tried to post a picture the CCF way and it worked too,
The Atta Boy would have been appropriate about 6 months ago, but these days I'll stick with IMGBB.
The Atta Boy would also have been appropriate if there was any kind of communication at all from Keith about the issue in the last 6 months
I'll guess that since his wife posted a picture on June 21 to promote selling CCF apparel they noticed that pictures weren't working and fixed it then so they could get a picture of some shirts posted
Just a guess of course  Wink
359 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 359 Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2023 at 7:28am
Speaking of pictures, I was at the lake looking at my boat on the lift and should have taken a couple pics. I realized that I'd have to move the flip flops closer to the center to keep the hull off the cradle, at least in front. Rear too probably, but the water was chilly and I didn't want to go that deep. I'm a little concerned about the boat tipping over if they are as close as they need to be, and the 2x6 on edge are going to take up water depth I don't have. Maybe I'll try to add another se tonight of pier and move my lift deeper. Maybe look for a Shore Master lift instead.
