Sherwood strainer |
1993R ![]() Groupie ![]() Joined: July-27-2005 Location: Hawthorne, FL. Status: Offline Points: 52 |
![]() ![]() ![]() ![]() ![]() Posted: January-03-2025 at 4:44pm |
It’s getting cold here next week in north Florida and I’m preparing for it.
Ran into a problem with the above strainer model is 18005 I haven’t drained it and cleaned in a couple of years. I live on spring fed sand bottom lake so not a lot of debris. I cannot seem to get it disassembled Any good tool or tips to getting it unscrewed and drained? Also is it standard direction or reverse? Thanks all
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11236 |
It rotates in the normal direction, lefty loosie and righty tighty......just like a jar of peanut butter If you have an oil filter wrench for a Ford filter like what's on your boat (FL-1A, Fram PH8A etc) it fits on your filter just like in the pictures below and should take that thing apart. My psychic powers seem to tell me that you use a K&N filter with a big nut on the enf, so you may or may not have one of this type wrench ![]() And.....if nothing gets it off, pull the hoses off and take it in the house / garage |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21207 |
Strap wrench for the strainer bowl usually works well.
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3024 |
I also lube up the gasket and threads with a thin layer of petroleum jelly. This helps everything go back together well and make the next removal job quite a bit easier. Those threaded plastic pieces seem to gall at times.
Thanks to all
I got it but had to remove it from the boat and use the oil filter wrench Thank goodness I have a ton of wrenches from my car racing days
