  New Posts New Posts RSS Feed - New coil - Tach not working
Rob-Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rob-Man Quote  Post ReplyReply Direct Link To This Post Topic: New coil - Tach not working
    Posted: April-17-2025 at 5:48pm
have 86 SN2001 - Everything is hooked up the same after the new coil but the tach is not working - any Insite would be appreciated?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rob-Man Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2025 at 5:51pm
Also wanted to add to this post.  The hour meter never worked in the 10 years, i have had the boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2025 at 11:13pm
Is the tachometer signal wire (usually gray in color) connected to the negative ( - ) side of the coil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rob-Man Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:15am
I will check when get home thanks.
