HEI Distributor for 82 nautique w/ 350 |
Jason
Guest |
Posted: June-22-2004 at 5:37pm |
I have an 82 ski nautique that came with a chevrolet 350. I would like to eliminate the points and condenser and replace the entire unit with a chevrolet hei distributor. You can buy used ones pretty cheap.
My only question is, how does this work with our reverse rotation engines. Do I just need to use my gear off the old distribtor on the new one? Or is there something else involved. thanks in advance |
Dan-H
Newbie Joined: June-24-2004 Location: United States Status: Offline Points: 4 |
Not sure on the chevy, but I recently installed a pertronix solid state ignition with a new high output coil and it made an amazing difference.
the instructions showed install steps for both rotation directions of the dist. it is a prestolite distributor. YMMV, - Dan |
83 ski nautique
AWhite70
Guest |
If you want a HEI distributor check out http://www.performancedistributors.com
They make a marine version HEI distributor for chevy's for $310. Make sure you ask about a reverse rotation gear. That should be the only difference between LH and RH I recently bought one for my 351W and am very happy with it. The only downside was they charged me $75 for the reverse rotation gear, they claimed that was close to what they pay for them. Overall the outfit had great service. The product was good, and they are very confident that their calibrated timing curves are much more accurate than stock distributors. |
nms1991
Guest |
the chevy engine does not need a reverse cut gear because they turn the cam the same direction for either rotation. The left handed engine uses timing chain and the right hand uses gear to gear to acheive this. the gears are cut the same direction for the chevrolet based engine.
Jason
Guest |
So a standard chevy hei automotive distributor would just drop in???
I can get a brand new auto version for $100 shipped, instead of spending $310 for the marine version. Whats the difference between the marine and auto? Is it worth it to spend 3x the price. |
79nautique
It all depends whether or not you want to blow the engine cover off when your automotive dist. arc's and ignites the gas fumes trapped in the cap then the flame from it ignites the rest of the fumes in the engine compartment.
Spend the money the car version does not have flame arrestors or the corrsion protection a marine grade does. |
kenny g
Senior Member Joined: December-13-2003 Location: United States Status: Offline Points: 318 |
you get right to the point don't ya 79 ?
kenny g
79nautique
No since mixing words.
I guess the main thing is run at your own risk. Can you get by with an automotive dist. yes for how long, who knows? It all depends how well you have the lines attached and the condition their in and how long is it going to take to leak or build up gas fumes or DNR to look at it and write you a citation. |
79nautique
Jason
You really should try EBAY there's about four or so to pick from all under 300 beans |
