attn...randy in oh |
Guests
Guest |
Posted: January-31-2007 at 5:06pm |
randy.........couple questions for ya
1. can you post pics or tell me how you wired your amp..ie...to the boat battery or are you running 2 batteries?......if so are they daisey chained?......curious how you grounded? where dide you run the wires so there are hidden?...trying to find out how to run the wires to the battery without seeing them?........all make sense?..........thanks |
Randy_in_Ohio
Ryan,
I just noticed this post sorry I only have one battery. I suppose you could put in two connected in parallel,(not in series or you will have 24 Volts!) but unless your installing multiple amps i don't see the need. I ran the positive wire straight to the positive terminal of the battery and the Negative to the block. I ran all the wires along with existing wires. What exactly do you have to install? let me know if you need some help. |
