  New Posts New Posts RSS Feed - Oil Pressure Gauge
Oil Pressure Gauge
goligmj View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote goligmj Quote  Post ReplyReply Direct Link To This Post Topic: Oil Pressure Gauge
    Posted: June-25-2004 at 12:52am
All,
Please help, my oil pressure gauge in my 1988 nautique bounces all over the place. I put a spare gauge I had from my 85 nautique in it and it does the same thing. I know when that gauge was in my 85 it did not bounce? Sending unit? can that be the cause? Bad ground wire?
Thanks for any help...
77stang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2004 at 5:37pm
re: bad ground,
turn on your dash lights and if that gauges light flickers with the bounce i would think that would be it. how bout a bad seending unit wire? does sound like a connection item.
good luck
Dan-H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan-H Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2004 at 3:33pm
you can test the sender by connecting your extra guage directly to the sending unit. If it still bounces, replace the sender, otherwise it is likely the wiring.
83 ski nautique
