86 Silver Nautique Tranny Fluid |
SunOrSnow
Newbie Joined: July-09-2004 Location: United States Status: Offline Points: 10 |
Posted: July-09-2004 at 6:29am |
I purchased an '86 Silver Nautique 2001 with the 351 motor. No Manual. What type and quantity transmission fluid does it use?
Thanks in advance for any replies. Gordon |
NAUTI84
Senior Member Joined: June-10-2004 Location: United States Status: Offline Points: 485 |
I've got an 84 w/ a 351 Ford PCM.
The PCM manual I have lists: ATF Type A, Suffix A, Dexron. Capacity lists: Model AS1-7C 1.8 qts. @ level & 1.3 qts. @ 15deg incline. Instructions: Boat at rest in water. Fill to top mark of dipstick attached to plug. Replace plug, start & idle for short time to fill all circuts. Stop & check level again, fill to top mark. Hope this helps |
SunOrSnow
That is just what I was looking for.
Thank You! Gordon |
JIMMY
Guest |
I JUST PURCHASED A 1986 SILVER NATIQUE ALSO. I TRIED TO GET SOME INFO. ON THIS MODEL AS FAR AS BEING A SPECIAL ADDITION BUT NO LUCK. I EMAILED CORRECT CRAFT IN FLORIDA AND THEY MAILED ME A MANUAL FOR THIS MODEL NATIQUE. IF YOU HAVE MORE INFO. ON THE SILVER NATIQUE, PLEASE LET ME KNOW. AND IF YOU DON'T MIND, HOW MUCH DID YOU PAY AND WHAT SHAPE WAS IT IN. IF YOU REPLY, WE WILL COMPARE TO SEE WHAT KIND OF DEAL WE GOT. THANKS
David F
Hey Jimmy:
It is generally considered better form to post in lower case type. Some consider all caps to be a form of yelling or shouting. For me, it is just easier to read lower case type. Also, do not forget the "U" in Nautique. Congratulations on your "new" boat. |
Troy
Guest |
I also recently aquired a 86 Silver Nautique and was wondering about its origin and how many were made etc. What did you find from the brochure? Mine is in rough shape as it sat in the water for years. I've got it running good. Now to the apolstery and removal of bottom paint.
Keith
Admin Group Owner / Operator of CorrectCraftFan.com Joined: October-20-2003 Location: Pepperell, MA Status: Offline Points: 1917 |
Just picked up my own Silver Nautique 2001. 82 of these boats were made (out of 1,305 total Ski Nautiques in 86).
Everyone, please post pictures of your Silver Nautiques to the Diaries Section so we can all see them. Mine needs a little cosmetic work. Looking forward to getting it back to orginial. A member of the site has a Silver Nautique brochure. Should have a scanned copy up on the site shortly. -Keith |
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5323 |
CONGRATS Keith!! Most of us "regular guys" know you've been in the hunt for quite some time. We know your exicited and on cloud nine. Boat looks GREAT!
