Prop Test: Acme #540 vs. '79 Federal |
Page <12 |
Munday ![]() Gold Member ![]() Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
Hi, Gottaski exzactly like that!!
Only thing I could add I like neversieze in final install, Great site here |
GottaSki ![]() Guest ![]() |
Hey Munday.! Just one ?
I was always hesitant to use a lube on the taper...Do you see any distortion of the keyway or key? I was thinking I wanted the taper to take most of the torque, and the keyway was there in case some slip occured.. Let us know! |
new86owner ![]() Groupie ![]() ![]() Joined: August-02-2004 Location: United States Status: Offline Points: 78 |
FYI,
I have read the reviews and am about to order the 542 prop for my 86 SN 2001. I found this source that has these props for $300. http://www.marinepropshop.com/acmeprops.html |
Rick ![]() Senior Member ![]() Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
Gottaski I didn't have a propguard on my 66 trailer so I removed the prop to trailer it. I never saw an distortion of the key or keyway. By the way I also bought an 8' piece of 1/4x1/4 brass stock for 8.00 so I have a ton of extra keys just in case.
cinekw ![]() Newbie ![]() Joined: July-28-2004 Location: Canada Status: Offline Points: 22 |
For sale ACME #540
Bought it brand new for my 1980 Ski Nautique, used for 2 weeks and sold my boat with the original one, I am in Canada which means that I had to pay for shipping Customs TAX, so If there any Canadian SN owners that are interested in saving some money then this is a deal for you. US customers welcome Price $400 Canadian FIRM. Boat replaced with 1990 NS which needs differnt prop. |
jacob ![]() Guest ![]() |
How much to ship to America 37221?
Jacob |
ultrahots ![]() Gold Member ![]() ![]() Joined: September-08-2004 Location: United States Status: Offline Points: 618 |
Do not hit the puller to hard.This is to simply pop the prop free.It should then slide off the shaft.A brass punch and a nice hammer will have the same results as a puller.I do not reccomend doing it often but in a jamb it will work.
I have an OJ 4 blade and an Acme 540 (bent up the OJ and could not wait for the repair)And the Acme is a Hands down nicer all around prop for skiing.The OJ has a very large wake at about 23 to 25mph (larger than the Acme) but that is about it. |
Keith ![]() Admin Group ![]() ![]() Owner / Operator of CorrectCraftFan.com Joined: October-20-2003 Location: Pepperell, MA Status: Offline Points: 1917 |
Update: My 540 went with my Mustang when I sold it. Even though I primarity slalom, I found a Acme 542 on eBay for a great deal and picked it up. This prop is just as amazing at the 540. Whole shot is unreal. I'm now pulling up slalom skiers at 1/4 throttle (otherwise I'm ripping the rope out of there hands). I gained 1 mph and about 250 rmp at WOT (4,800).
Couldn't be happier. -Keith |
Steve ![]() Guest ![]() |
I am stuck on a 4 blade, but have done exhaustive research on the "net" and I am told the Acme 540 is the way to go. I have an 86 Ski Nautique, with slight engine mods (for a little more horse, ignition, carb, exhaust, etc), and pull 2 heavy bare footers without a problem. Looking for more hole shot....and to keep top speed. Boat mostly used for slalom skiing and barefooting, with some wakeboarding mixed in... Barefooters use step off ski's, cause the drag time behind the boat is very long.... Also, we pull multiple skiers often... So in essence, top speed is fine, just need more holeshot, and want to keep top speed.... I can't get over that a 3 blade has more "pop" out of the hole than the 4 blade. I almost purchased the Acme 4 blade, 13x12.5" RH 1", but am holding out..... Might get a 3 blade ACME 540... Looking for some more guidance.... Thanx, Steve |
Ryno ![]() Newbie ![]() Joined: August-01-2006 Location: United States Status: Offline Points: 7 |
Since we are now in the year 2006; does anyone have any recommendations for a 1971 Ski Nautique prop upgrade?
Thanks! |
Ryan
64 Skier ![]() Senior Member ![]() Joined: February-08-2004 Location: United States Status: Offline Points: 415 |
I have the 542 on my hull and it's a great prop. It runs 30 MPH at 3000 RPM's and 36 MPH at 3600 RPM's. All readings confirmed by two GPS's since I thought it was supposed to have 200 RPM's more at each of the referenced MPH sets, thus the double check with the GPS units.
Pulls a 240 slalom skiier on a 67" " HO Truth" with less than 1/2 throttle....and that's a big ole boy on a little bitty ski! I have a rebuilt 289 with slight mods to intake & heads but more compression. IMO this is still a good prop even if your engine is tired and the foam in the hull is water soaked.....or....you weight up with fat sacs and have 4 people in the boat. My boat porpoised with the original prop and soaked foam. I still don't fully understand why but when I put this prop on the boat it stopped porpoising. |
Thanks for the information and input! My boat has a Chrysler 318 w/ 340 heads; manifold,and holley 4 bbl. It is a very clean restored 1971 Nautique that i bought recently. I have been skiing a few times and am looking to flatten the wake and reduce the prop wash which is why i was intrigued by the article about the prop upgrades. I weigh 155 and ski a 67 Connelly F1...no problem with power or weight issues just looking to get the best out of an old hull so i can keep on beating up my old body! Other than myself my wife skis and my 6 year old got up last weekend!
Thanks again for the info, i truly appreciate it. |
Ryan
The Lake ![]() Platinum Member ![]() ![]() Joined: May-13-2005 Location: Lk Winnebago MO Status: Offline Points: 1157 |
Hey Ryno, I have a 60 Nautique, and when I put the 540 prop on we got a lot better perromance. (I also have a 318 Chrysler) I saw great improvement with the hole shot and a flatter wake.
Have you posted any pictures yet? I'd like to see your boat. Chuck |
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13523 |
Here's some info on the Michigan Wheel 13x12. I used ~5 year old Garmin handheld GPS.
14.5 mph @ 2000 rpm 27.5 mph @ 3000 rpm 37.0 mph @ 4300 rpm These speeds look low but I ran it several times in smooth water with just a driver (170 lb), 50 lb of gear and 1/2 tank of gas in a 1988 Ski Nautique with 960 hours, original engine/trans. |
79Tique ![]() Senior Member ![]() ![]() Joined: September-04-2006 Location: United States Status: Offline Points: 380 |
Hey Guys, My 79 Ski Tique seems to have a smaller prop than the Nautiques I have seen. I noticed that Zigzag mentioned a concern about clearance and I am wondering about this as well. My boat has the stock prop and I think it looks pretty small. We ski most of the time and do a little wake boarding and I feel the boat could pull a skier up a little quicker. Any one know what will fit and make my Tique with a 302 and help it gain speed quicker?
Work to live, not live to work.
wsavini ![]() Senior Member ![]() Joined: September-06-2012 Location: Taunton, Ma. Status: Offline Points: 282 |
Is there any newer updates on props? These post are 8 years old now. Thanks
Federals still suck. :/
phatsat67 ![]() Grand Poobah ![]() Joined: March-13-2006 Location: Indiana Status: Offline Points: 6157 |
Acme Still roolz
M3Fan ![]() Grand Poobah ![]() ![]() Joined: October-22-2005 Location: United States Status: Offline Points: 3185 |
And the '88 still only goes 37. ![]() |
FLCaptain ![]() Groupie ![]() ![]() Joined: February-10-2019 Location: Orlando Status: Offline Points: 45 |
Do you still have the review? I'm thinking of a 540 or 542 for my 1979 Ski Nautique. I just put 1988 Exhaust Risers on it out of Necessity. I have a new prop and bushing. Would still love to smooth it out and gain some power.
Morfoot ![]() Grand Poobah ![]() ![]() Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5334 |
Best prop for that boat is gonna be a 540. The 542 is lower pitched so your hole shot will be slightly faster than a 540 but your top end will be slower than a 540. Go with the 540!
Page <12 |
