  New Posts New Posts RSS Feed - dist hookup problems
logicsound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote logicsound Quote  Post ReplyReply Direct Link To This Post Topic: dist hookup problems
    Posted: March-30-2007 at 5:38pm
ok I know my firing order it is 5678 on the pass side and 1234 on the drivers side (its written on the intake) but I dont know where to hook them up on the dist cap. ( there are no numbers at all) just got the electronic upgrade for the dist. also Im guessing I need to retime now, so I know how to get to tdc but then what?
87BFN owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2007 at 5:58pm
There should be mark for the number one plug wire on the distributor cap, then put your plug wires on according to firing order from there. When you do the timing make sure the rotor matches the number one plug wire on the cap. If anything it my be 180 off, just rotate accordingly. If there is no mark already on the cap, mark number one yourself and go from there. Just make sure the rotor button matches the one you pic for number one when it supposed to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote logicsound Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2007 at 6:03pm
do I go left or right from number one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2007 at 6:04pm
depends on rotation of your motor. You go with the direction that the dist. spins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote logicsound Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2007 at 6:17pm
thanks, but I think I F**ED, after getting a new coil, new wires, and the electronic ignition upgrade I am still getting no spark, and like another forum on here as soon as I turn the key off I get a big spark.
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2007 at 6:41pm
Take a deep breath logic. Screwing up your plugs wires has got to be the most common mistake made.
Pull the coil wire, make sure the ignition is off. Pull plug #1, using a breaker bar and socket turn the engine in the direction that it would run until you get #1 cylinder to top dead center on it's compression stroke. To determine the compression stroke put your finger in the plug hole, with the piston on it's way up you will feel pressure forcing you finger out. That's what you want so then turn the motor with the bar until your pointer is on TDC on the balancer. Remove your cap and the rotor will be pointing to #1. That's where #1 wire will go and then Install the rest of the wires in the correct firing order and you should be good to go.
It's quite simple but easy to mess up, take your time and think it through.
Post Options Post Options   Thanks (0) Thanks(0)   Quote logicsound Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2007 at 7:26pm
thanks 81. But I think I have bigger problems. Just had a buddy come over and do exactly what you said but still no luck. I am getting no spark. but I get a big spark when I turn the key off, rotor does turn though
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2007 at 10:36pm
    Big spark when your turning the key off means that there is a issue where your coil is being grounded all the time. The ground to the coil should pulse at every cylinder fire.
                                      Jeff...
Post Options Post Options   Thanks (0) Thanks(0)   Quote logicsound Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2007 at 9:25am
ok thanks, I have 2 wires on the - side of my coil. The black one that goes to dist. (electronic conversion) and a grey one that goes towards the back ( it is in the wiring harness)
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2007 at 9:43am
well that's the problem, you should have atleast three if not four wires connected to the coil. grey (-) and purple (+) wire from the harness and then two leads from the electronic conversion or one lead from the points.
if you only have one lead coming from the dist with a conversion kit then the kit isn't installed correctly, you have to have a power feed to the conv as well as a ground, one wire systems are for point type ignitions only. With one lead you cannot supply power to the module for the conv kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote logicsound Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2007 at 9:56am
thanks..I was just answering the negative part of the reply above. To clafiy..
I have the purple wire from the harness and the red wire from the conversion kit on the + of the coil and the grey wire from the harness and the black wire from conversion kit on the negative.
