  New Posts New Posts RSS Feed - engine idle
engine idle
97Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 97Nautique Quote  Post ReplyReply Direct Link To This Post Topic: engine idle
    Posted: April-22-2007 at 8:44am
I just bought a 97 ski nautique. What is the correct idle speed? It idles at 900 rpm which seems high, and the boat is moving pretty fast at idle. Should it be more like 500-750 rpm?
Thanks
97Nautique
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2007 at 11:06pm
I like my 92 at 800 in gear and thats still pretty fast,
Munday
Post Options Post Options   Thanks (0) Thanks(0)   Quote 97Nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2007 at 11:24pm
Thanks Munday,
I just found the specs in the reference section. 650-700 rpm idle in gear. Now I just need to figure out how to turn down the idle. I found the idle control, now I just need to see if there is an idle set screw of if it can be done by adjusting the cable.
I'll keep looking but any suggestion would help.
Thanks
97Nautique
9360SAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 9360SAN Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2007 at 5:05am
It's pretty easy,Trace the throttle linkage,near air intake/flame arrestor,will find a hex screw for trim idle speed, use a no.8 block,you should trim after engine warm to 650RPM, but I think the former owner ajust higer RPM for some reason.
Go on wakeboard
