need parts |
burdiejr
Newbie Joined: May-01-2007 Location: United States Status: Offline Points: 23 |
Posted: May-05-2007 at 11:31pm |
ok brought my nautique home today. i need a raw water pump. i'm not going to rebuild it....its old i'd rather have new. i'm also gonna put a circulating pump on it....appears original. i'd like a to see a parts sheet so i could pick out the parts i want i also need some hoses. any idea where i can find such things.
burdiejr
ok sorry pc messed up sent me to blank page didn't realize it actualy posted
boat dr
burdiejr,took all the stuff you need off my motor,new raw water pump,circulating pump is sold but i have everything else.What hose do you need?...........boat dr
79nautique
well unless the bearing is shot there really isn't anyhing to re-build just replace the impeller, Now if you don't use a sea strainer and dirt and sand has grooved/scored the end side then your going to have the same problem again with a new one.
burdiejr
i need both pumps....what would you take for your raw water pump? if you'd like you can call 919 920 9216 thanks, brandon
