ENGINE MISSING AND STALLING |
BEBS ![]() Newbie ![]() Joined: August-05-2004 Location: United States Status: Offline Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: August-05-2004 at 1:55pm |
Once my 80 Ski Nautique is warmed up (about 15 - 20 minutes) it starts missing and eventually stalls. After that, it has a hard time starting and will quickly stall at idle.
I have performed a full tune up (with the exception of the coil) and I have had the carb re-built. The same problem persists. Any suggestions? |
79nautique ![]() Grand Poobah ![]() ![]() Joined: January-27-2004 Location: United States Status: Offline Points: 7872 |
Do you still have the org. point style dist.? If so check the points and condenser and the coil is a possiblility as well. If you have convert it to electronic check the module. Once the engine gets up to temp the heat could be effecting the condenser, coil or module causing a short thus the mis-fire.
David F ![]() Platinum Member ![]() Joined: June-11-2004 Location: United States Status: Offline Points: 1770 |
Also check the ballast resistor by connecting a jumper wire across the two terminal posts. If the engine then runs fine, replace the ballast resistor soon as you risk burning up the coil.
Dan-H ![]() Newbie ![]() Joined: June-24-2004 Location: United States Status: Offline Points: 4 |
Have you confirmed it is a no-spark condition when it is failing? easy to-do, just bring a timing light. Assuming it is no-spark, bypassing the ballast resistor might mask a weak coil. best to test the ballast resistor with a voltmeter when it is having problems. Or just try a new coil. they are cheap and easy to replace. |
83 ski nautique
Tim D (#2) ![]() Newbie ![]() Joined: April-26-2005 Location: United States Status: Offline Points: 4 |
My '85 sn 2001 did the same thing. After checking it all out it turned out to be a combination of two things. Fuel filter partially clogged and the coil.
I agree with Dan. Go ahead and replace the coil. |
Tim D (#2)
Jim_In_Houston ![]() Platinum Member ![]() Joined: September-06-2004 Location: United States Status: Offline Points: 1120 |
I am amazed at how often coils do fail. It must be the heat and vibration that does them in.
Until recently I have carried a spare coil under my seat - I had to use it. I have never had a ballast resistor fail although I can see how it is extremely possible. |
JEFF KOSTIS ![]() Gold Member ![]() Joined: April-19-2005 Location: United States Status: Offline Points: 817 |
More than likely it does sound like a ignition problem, however if that doesnt cure it you might want to pay attention to the fuel system. See when it misses/stalls if its running too rich or lean. (black smoke?) Our 1974 mustang 17 omc 225 for a while would not idle and run rich when it got up to temp and it was due to just a bit too much fuel pressure to the carb. We had this problem for a while and took a while to figure out. I kept on playing with the carb float and no change. To make a long story short I fabricated a spacer for the fuel pump to achive 5 lbs of pressure. The float(new and old) could not handle the hot fuel since its less boyant. Good luck!!!!
Seems to me that the problem is a stuck or non-sealing needle valve in the carb. During warm-up, the engine likes and needs the extra fuel. However, after warm-up the extra fuel will flood the engine while trying to idle. Simple check is to look down the throat of the carb while it is idling. If fuel is dribbling or pouring out of the venturies, then the needle valve is not closing properly.
Other clue is hard starting once the engine dies from flooding. If the engine requires full throttle starts, then another sign of a flooded engine. |
Tim D ![]() Grand Poobah ![]() Joined: August-23-2004 Location: United States Status: Offline Points: 2641 |
Check the intake manifold, might be some loose bolts. When it is missing, are there any signs of black smoke? Did you replace the distributor cap and rotor? If it is your coil, Accel makes a coil for heat and vibration. I have it on my boat, it has a gel instead of oil in it.
Tim D
As i was going to sleep last night I thought of another possibility if its not a fuel issue. Have had PCM 302/351 and OMC 225 engines with either presolite or mallory distributors fog up inside the cap due to the engine warming up and water evaporating from the hull. I noted this especially happens on cooler, more humid days (first thing in the morning) and no matter what it doesnt want to run and gets worse. A missing or damaged gasket that goes on the cap can give you serious problems. My neighbors Ski Centurion did the same thing but it was a hot, non-humid day. Put on a new gasket (missing)-all ok. However we can be guessing forever, we need to know if its a fuel problem (running rich) to rule out ignition.
80nauts ![]() Groupie ![]() Joined: March-19-2005 Location: United States Status: Offline Points: 93 |
Usually a when a fuel pump starts to go out of service it will fail when it warms up. If you let it sit for a while then it will start again but usually fail even faster since it was previously warm. Eventually it will completely fail.
It sure sounds like that is what's happening by it not starting anymore after the first initial warm fail. If you replace it then make sure it is a marine grade pump even though they cost a lot. The automotive ones have a seepage hole to let you know when they go bad, but you relly don't want your boat filling with gasoline when it goes bad. |
