  New Posts New Posts RSS Feed - 2001 SKI Natique wont start
SCHOOL2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCHOOL2001 Quote  Post ReplyReply Direct Link To This Post Topic: 2001 SKI Natique wont start
    Posted: July-10-2007 at 12:09am
Havent ran boat in 1 year because of move. Now I am ready to go but boat wont start. I have spark but no fuel. Not sure if sending unit or pump. I get no fuel to carb. I can start if I pour gas in carb. Help I want to go out.
Thanks
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 12:17am
what year and motor? 2001 or 82-87 2001 hull?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCHOOL2001 Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 12:22am
1984 ford351
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 1:09am
well first thing to try is to narrow it to the tank or the pump. Get a can of gas and run a hose from the suction side of the fuel pump to the gas can and see if it will run. If it does then trace the fuel line back until you find something clogged. If it doesn't start then you need to see if it's an issue with the carb so disconnect the fuel line at the carb attach a fuel pressure gauge and see what the pressure is. Try that out and get back to us with the results.
