Water Trapped in Hull |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4248 |
Posted: August-06-2007 at 1:06pm |
When I get some water in the boat, some of it gets trapped in the left side stern, outside the stringer. I'm sure there are holes that should allow it to flow into the bilge but not sure where, and haven't pulled up floor boards yet. Anyone know where they are located?
63, Are the stringers still factory or have they been replaced? I don't think you will find any drain provisions if they are original. If they have been replaced and you are lucky then whoever did the work put them in.
63 Skier
They are original. This problem just began last summer but now won't drain at all, prior to that it drained fine, so there must be something plugged. Its easy enough to add drain holes but I haven't had time to lift the floor and back seat to look.
You should see me, I get on plane, steer hard right, then throttle back to get most of the water into the bilge, I assume it is flowing up over the stringer, then I pump it out. People must think I'm crazy when they see this maneuver. |
Munday
Gold Member Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
If you do add drain holes you need to seal the wood.Pipe cleaners and epoxy is what I'd do.I've also used ballons to hold small pieces of wetted out mat into place when sealing holes thru stringers
Munday |
RainDog
Platinum Member Joined: February-21-2007 Location: Mke/Grn Lake WI Status: Offline Points: 1387 |
I had the same problem on my 62 Classic.
It turned out that a mouse made a nest in there a long time ago. Its nesting material blocked the drain hole. I had a piece of flooring under the seat bases that came up easily to clean it out. |
63 Skier
Where exactly are your drain holes? All the way aft? I'm just wondering if I have to remove the back seat or not.
Munday, I'll seal them if I have to add them, might seal existing ones if I find them as well. I've never heard that balloon trick, that's pretty clever, will keep that one in the memory bank. |
phospher
Gold Member Joined: July-19-2007 Location: United States Status: Offline Points: 557 |
lol, that's funny. not your problem but how you describe your maneuver. good luck! |
RainDog
Mine were a little fore of the front seats. My drain hole is also a little fore of the front seats as well. This is the low point of the boat when on the water.
Maybe you could fish a shop vac hose up your hull and see what it picks up. |
63 Skier
Fore of the front seats - now that's a surprise to me, I'll look closer. My drain is there of course, but for some reason the water seems to collect aft, or maybe that's just where I see it. I have to repaint my floorboards anyway, plan to do it in the winter, so I'm trying to avoid taking the floor apart now. I do have the large panel that comes out easily in front of the front seats, I'll really duck under and look this weekend.
63 Skier
You were right, I found the holes through the stringers ahead of the front seats. I fished a wire through to clean them, a bit of water flowed, but after it stopped there is still water trapped all the way aft. Hmmmm .... Maybe another hole aft, looks like I'll have to pull the floor boards after all.
