  New Posts New Posts RSS Feed - Refiberglassing floor 92SN
Pgaski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgaski Quote  Post ReplyReply Direct Link To This Post Topic: Refiberglassing floor 92SN
    Posted: October-17-2007 at 11:10pm
Can anyone tell me how much fiberglass and Resin I will need to redo the stringers and floor. What weight of cloth. ETC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2007 at 11:23pm
This is from a complete thread on stringer replacement by Bill (skibum)
Posted: 13 October 2007 at 7:12pm | IP Logged | Report Post      Quote bkhallpass
Here is the shopping list posted by Bill (SkiBum) on March 15. It is from a thread started by Jon4Pres regarding the stringer floor replacement in his 82. BKH
To replace the stringers this is a pretty good list of materials:
quan      item
5 gal     Epoxy resin 635 thin 3:1 ratio
1 roll    50 yds 2" E-glass tape
1 roll    50 yds 4" E-glass tape
1 roll    50 yds 8" E-glass tape
5yds      Epoxy mat
5qts      West 404 filler (fine glass)
5qts      Aerosil-Cabosil thickening agent
5qts      Fairing compound
25 ea     2" wood paintbrushes
25 ea     stir sticks
5 ea      1qt mixing containers
2ea       2"x10"x16'
2ea       1"x6"x12'
Each stringer consumes about one gallon of epoxy resin from start to finish. Use the epoxy mat to laminate both sides of the stringers. Seat the stringers with 2 layers of epoxy mat and clamp until cured. Fill gaps with 404 filler and epoxy. Then use 2", 4", 8" strips along the joint. Use 404 and epoxy to make a bead 1" above and below the joint 1/4" to 1/2" thick.
That is all it takes to laminate and install the stringers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgaski Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2007 at 11:35pm
Thanks!!! I pulled out the wet foam and rotted stringers. I think the boat lost about 150lbs just in water weight stored in the foam under the floor.
