  New Posts New Posts RSS Feed - adding fuel return to tank
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Topic: adding fuel return to tank
    Posted: October-11-2004 at 2:15pm
I need to add a fuel return fitting to the plastic tank of my '93 SN. Has anyone done this successfully and, if so, how?
My thoughts:
1. Replace the vent elbow with a "T" fitting so the fuel return would dump in where the vent is located. My concern is that the returning fuel would block the vent from working or dump fuel overboard. I know when the engine is shut off, the vent would do its job. The engine is off often, so I believe pressures would be equalized often enough to avoid problems.
2. Find or make a fitting than can be spliced into the filler neck hose. Such as a stainless steel pipe with a fitting welded into the side.
3. Tap the top of the fuel sending unit and add a barbed niple. Has anone done this and is there enought room on the sending unit flange?
Any other ideas?
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2004 at 10:40pm
I like the t in the vent especially if you put a fuel vapor seperator in line above the T.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2004 at 11:43am
Rick:
OK, I like this idea best as well. However, can you enlighten me on what a fuel vapor seperator is or where I can see the specs on one. Thanks
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2004 at 2:02pm
here is a link http://www.skidim.com/prodinfo.asp?number=LG-50&variation=&aitem=25&mitem=53 from SKIDIM
workky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2004 at 5:19pm
I take it you need a return line for an electric fuel pump.If so what kind of fuel pump are you running?I converted my 84 2001 to a marine holley pro-jection.I had to run a return line in mine as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2004 at 5:52pm
Well, yes I need the return line due to an electric fuel pump. However, the pump is the result of swapping in a complete (low hour) '95 PCM "Pro Ski" throttle body electronic fuel injected engine/tranny.
How did you add the return line to your tank. Does a '84 have an aluminum or plastic tank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2004 at 2:19am
Mine has an aliminum tank so it was fairly simple.I pulled out my sending unit and drilled a hole in it,tapped it and ran an elbow in it.There isnt a lot of room for error,but if i screwed up i could just replace the sending unit.What's wrong with the power plant thats in there now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2004 at 2:21am
I tried what u described with the tank vent and it worked,i did it just as a testing thing ,making sure i could get the fuel injection to work.I felt a little better with it running to the tank
