MSD CHEVY DISTRIBUTOR |
NEDLUTZ ![]() Groupie ![]() Joined: November-26-2007 Location: Seekonk Ma. Status: Offline Points: 69 |
![]() ![]() ![]() ![]() ![]() Posted: December-09-2007 at 5:06pm |
MSD 83606 - MSD Pro-Billet Ready-to-Run Marine Distributors MSD’s new Ready-to-Run Marine Distributors are the perfect upgrade for boats that are relying on worn out breaker points or weak ignition systems. These new distributors feature a powerful ignition module built into the billet aluminum housing. This module produces a stout inductive spark that will improve combustion of the fuel mixture for better driveability. Beneath the durable bolt-down, injection molded cap, a maintenance-free magnetic pickup produces accurate trigger signals while an oversized shaft is guided by a sealed ball bearing. An easy to adjust mechanical advance allows you to custom tailor a timing curve to match your application. The Ready-to-Run Distributors are a breeze to install. Simply drop it in the engine and connect three wires and you’re ready-to-run across the lake! Supplied with a cap, rotor, gear and Weathertight wiring harness. |
79nautique ![]() Grand Poobah ![]() ![]() Joined: January-27-2004 Location: United States Status: Offline Points: 7872 |
good luck with that 95% are ford blocks and another 4% are chevy BB, so don't hold your breath.
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21210 |
...and the few vintage Nautiques that do have SBC's will be reverse rotation. Im assuming this MSD is standard. No idea of a modern EFI engine could use it, though those engines would be LH. |
I had it in my BFN it made big change in the power.
My mistake- it works for a reverse rotation BBC, then. Actually, it probably works for both reverse and standard rotation motors since the cams spin the same way. Tough to tell from MSD's site since it only says "Chevy V8."
It made a big change in power at the take off , like night and day
Brian, I'd say you had a problem with the original distributor or ignition system. A gain in spark is not going to make a "night and day" difference. |
Not necessarily, Pete. Theres a lot to be said for a proper advance curve and a stronger spark. I gained quite a bit with my DUI over the stock Prestolite with EI conversion- 200RPM on the top end, to be exact. |
75 Tique ![]() Grand Poobah ![]() ![]() Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6132 |
Tim, would it work in my 305? Not sure I need to change tho. I constantly had ignition issues with the supra, especially in the spring each year trying to get it going. I gotta say the chevy always starts very positivley, even first crack in the spring. I'll probably just leave it alone, but I do hear good things about EI, so I thought I'd ask. What do you think? |
“So, how was your weekend?†“Well, let me see…sun burn, stiff neck, screwed up back, assorted aches and pains….yup, my weekend was great, thanks for asking.†|
Larry, I dont *think* so, but Im not sure. Im not familiar with the way the small block Chevies were made into reverse rotation. The BBC's have a gear drive timing set, so the crank spins backwards but the cam spins like an auto engine- so it can use a regular LH distributor. The Fords have a conventional timing chain and both spin backwards (and need a reverse cut gear on the distributor). Im not sure which way the SBC's were done. Im also not sure if the small blocks and big blocks used the same distributor- I know they were different on the Fords. Hopefully someone else will know!
they are the same SBC and BBC but direction is key for the gears to work.
Chris, do you know which way the cam turns in a RR SBC? If it turns the other way, could he swap over his stock gear? |
don't know Tim might be able to, just looked on summit's site and it does list chevy dist. as be applicable to both small and big blocks but they also list a clockwise and counterclockwise models for the mallory units so i would say it makes a difference.
Larry, I spoke with the Boat Dr last night and he *thinks* this distributor would work in your RR OMC 305. He was fairly confident that you have a chain drive timing set, which means you would have to swap your stock gear over.
Anyone know any different? |
only ting that could prevent swapping the gears is if the old dist shaft is larger than the new one. Odds are it's the other way around and you might have to drill out the old gear to work.
you should be able to remove the rotor and mic the shaft to find out what the diameter of it is and then compare it to MSD's specs and go from there. |
Well, thanks for all your research and input gentlemen, but as you know, my knowledge of motors, excuse me, engines, does not go too far beyond, "the oil goes down into this thingy, doesn't it?" I think I will leave well enough alone. Like I said, It starts fast and runs good everytime (well I do seem to have a bit of a carb issue right now, but ignitionwise, it seems pretty tight.)
Thanks again. |
jbear ![]() Grand Poobah ![]() ![]() Joined: January-21-2005 Location: Lake Wales FL. Status: Offline Points: 8193 |
Your knowledge level is about the same as mine. I know something is happening under there...just not quite sure what. But if it is running "good every time" why take a chance?
BTW; Could not post when you put on the video...awesome job...thanks for putting me in it. john |
"Loud pipes save lives"
nuttyskier2002 ![]() Gold Member ![]() Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Have you found a buyer yet? I may be interested if the price is right. My number is 480-365-8989. Brian |
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
Brian, thanks for the phone call and explanation of the MSD distributor. With Christmas and ongoing projects with my new home I'm afraid a new distributor is going to have to take a back burner for now. If you still have it when Spring/Summer rolls around, I'd like to hear back from you. It was good talkin' to ya! Take good care and have a Happy New Year! - Brian
Still available?
David Garaffa ![]() Newbie ![]() Joined: October-25-2006 Location: United States Status: Offline Points: 3 |
David Garaffa
David Garaffa
