  New Posts New Posts RSS Feed - perko flush kit?  Recomend?  Where?
The Dude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Topic: perko flush kit? Recomend? Where?
    Posted: February-23-2008 at 6:33pm
Hi Guys. Sorry I've been away for so long. I ran the boat today and when I came back and hooked up the garden hose to the flush kit the plastic female end on the perko leaked all over the place. I messed with it a bunch, but it's leaking below the part that turns. I've only had this perko kit for about 3 years and I'm frustrated that it's already gone bad. I also noticed the new ones are quite a bit more than they were a few years ago. I think I paid about 30 bones for mine and the new ones at skidim are $58. Do you recommend I get a new one? If so, where do you have yours? Mine is on top of the muffler:
do you think it could be installed after the trans cooler, here:
Mullet Free since 93
95 Sport
1978 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-23-2008 at 7:45pm
David, Is there a rubber hose washer in the white female hose connection? Did you loose it? It works just like a garden hose. If the male doesn't bottom, then the swivel won't compress it's seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: February-23-2008 at 9:36pm
that's the first thing I checked and it's there Pete. It's leaking below the connection.
95 Sport
1978 Ski Nautique
The Lake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Lake Quote  Post ReplyReply Direct Link To This Post Posted: February-24-2008 at 3:05am
Dude, good to see your smiling mulletless face back on here. But, it's really not fair to be talking of getting your boat out when us north of the Mason Dixon line are still snow and ice bound.
Chuck
Walk on Water
www.coldwater.me
69 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-24-2008 at 10:56am
David, If it isn't broken below the white swivel then it must be a gasket problem. I would try a new hose washer or even two. With the hose connected and the white swivel tightened on the hose, the swivel should also tighten to the body of the flush pro.
The installed location is fine.
