hose clamps
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=10042
Printed Date: September-29-2024 at 1:31am
Topic: hose clamps
Posted By: phospher
Subject: hose clamps
Date Posted: April-04-2008 at 4:29pm
ok, this question may seem trivial to must but here goes,
i want to replace a few hoses that are looking somewhat brittle. my question is how tight to i tighten the hose clamps on the hoses? should the rubber be poking through the holes in the clamp?
just snug em up and run it. then check for water leaking and tighten more if needed? that's kind of my thought right now.
Posted By: Hollywood
Date Posted: April-04-2008 at 4:36pm
The torque specs are in the manual.
Posted By: phospher
Date Posted: April-04-2008 at 4:43pm
be nice if i had one. is that a manual on this site?
Posted By: 79nautique
Date Posted: April-04-2008 at 4:59pm
well I love the guys that quote torque specs, unless it's the bearings, heads, or fly wheel you really don't need no stinking torque specs.
But basically tighten them down as tight as you can get them within reason, usually using a screw driver isn't quite good enough, depends on your strength, But I like to use a short handled 1/4" drive ratchet on them. Seeing the rubber spread out some is good, just be carfull what your tightening against. Steel, plastic, tin can oil cooler as it will collapse if you over torque.
Posted By: phospher
Date Posted: April-04-2008 at 5:04pm
got it 79 thanks man.
Date Posted: April-04-2008 at 6:03pm
breaker bar with a 8' pipe extension
Posted By: BuffaloBFN
Date Posted: April-04-2008 at 6:10pm
Hollywood wrote:
breaker bar with a 8' pipe extension |
Only on the good clamps...?!!? LOL
Date Posted: April-04-2008 at 6:12pm
now we know why it took you so long to fix that carb.
Date Posted: April-04-2008 at 6:26pm
Carb never needed fixing, d*cking with that would just be a waste of time, go ahead if you want.
Date Posted: April-04-2008 at 6:31pm
so what was your problem last year being down on power or rpm or what ever it was you where complaining about?
Date Posted: April-04-2008 at 7:16pm
Distributator, will be looking at the springs and weights tomorrow morning actually. I don't have any way to remeasure the air gap for the EI though, so I'll be rigging something up hope I can get it back in.
Posted By: phospher
Date Posted: April-04-2008 at 7:21pm
hollywood, you been out to Powers Lake yet? is that lake even opening up yet?
Date Posted: April-04-2008 at 7:25pm
Don't know, will find out tomorrow. Need to patch a section of fiberglass so won't be getting it wet if it is open. Will be out next Saturday for sure.
Date Posted: April-05-2008 at 12:41pm
Hollywood wrote:
Distributator, will be looking at the springs and weights tomorrow morning actually. I don't have any way to remeasure the air gap for the EI though, so I'll be rigging something up hope I can get it back in. |
it should go back pretty close to where it was you shouldn't have to unmount it from the plate just leave it attached when you pull the cover plate to the advance, push the wires through the grommet some to clear the tip of the distr shaft.
