Rebuilt Carbuerator how to adjust?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=10244
Printed Date: November-16-2024 at 9:03pm
Topic: Rebuilt Carbuerator how to adjust?
Posted By: Southwind 83
Subject: Rebuilt Carbuerator how to adjust?
Date Posted: April-22-2008 at 4:41pm
I rebuilt my 4 bbl Holley last summer on my 83 southwind with a 351 ford. When I try to take off fast it almost dies then catches up and takes off normal. If I just ease into the throttle it takes of without hesitation. Is this a carb adjustment problem? How do you adjust the carb?
Posted By: 79nautique
Date Posted: April-22-2008 at 5:32pm
adjust the accelorator pump on the carb.
Date Posted: April-22-2008 at 5:56pm
How do you adjust the accelerator pump does it have its own screw adjustment?
Date Posted: April-22-2008 at 6:02pm
it's more like a nut that you adjust. on the left side of the carb towards the front you'll see a linkage arm with a screw/nut spring loaded deal just forward of the idle set screw that's where you adjust it if you still have the instruction sheet from the carb kit it should explain how to adjust it correctly.
Posted By: Tim D
Date Posted: April-22-2008 at 8:00pm
Might have to replace the cam.
------------- Tim D
Posted By: JUST-IN-TIME
Date Posted: April-23-2008 at 4:10am
if you want the holley manual
just email me
------------- www.switchbait.com
Posted By: backfoot100
Date Posted: April-23-2008 at 11:23am
Also set the idle mixture screws with the boat warmed up and in gear, not neutral. That has been posted numerous times in the past and IIRC it has fixed a few issues exactly what you describe here.
Eddie
Date Posted: April-23-2008 at 12:40pm
I love this website thank you all for your posts I will let you know what happens after trying all the things everyone has suggested!
Date Posted: April-23-2008 at 1:10pm
backfoot100 wrote:
Also set the idle mixture screws with the boat warmed up and in gear, not neutral. That has been posted numerous times in the past and IIRC it has fixed a few issues exactly what you describe here. |
yep just like packing!!!!!!
Posted By: ripsaw
Date Posted: April-25-2008 at 10:52pm
If I had to guess, widen the gap between accelator pump arm and bolt with spring, just tiny amounts makes a huge difference. I'm sure someone on here has the specs.
------------- 86 2001
