battery box
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=10448
Printed Date: November-19-2024 at 6:01pm
Topic: battery box
Posted By: tforrest
Subject: battery box
Date Posted: May-10-2008 at 4:19pm
This is my first correctcraft a 79 st . All of the water will never drain out of the battery box , is it ok to drill holes in the bottom of the battery box for drainage or should I just plug the existing hole. Thank you for all the great knowledge.
------------- Tommy Forrest
Posted By: SNobsessed
Date Posted: May-10-2008 at 8:25pm
I did this just to check for wet foam. Didn't find any foam but the hole let's in more water than drains out! I just sealed the hole up.
Date Posted: May-10-2008 at 10:24pm
Tommy, Be careful!! The bottom of the battery box is the bottom of the boat.
Date Posted: May-10-2008 at 11:06pm
I dont suggest drilling a hole. Besides the obvious chance of going through the hull by mistake, the water would not drain into the bilge anyways. The batt box is located forward of the front bulkhead, so that hole would only provide an easy access point to start soaking your foam and rotting your stringers.
Date Posted: May-11-2008 at 12:00am
There was about a 1/2 inch gap between the bottom of my battery box & the hull. No foam, no water, until I washed out the bilge. My bulkhead obvious isn't watertight because the water found it's way up there when the boat was nose down. Looks like I have some structural work to do next winter. No time for that now - it's almost ski season!
Date Posted: May-11-2008 at 11:41am
Chris, On the 70's style hulls, there isn't a battery box bottom.
We did have a guy drill through the bottom of his boat! No one believed me until I copied and pasted it over from the2001 to CCfan. I looked for it but couldn't find it!! Can't remember who it was ether. Maybe Tim does - he remembers everything!
Date Posted: May-11-2008 at 12:41pm
That definitely would let the water out, as long as it's on the trailer!!
Posted By: justrite
Date Posted: May-12-2008 at 3:09pm
Drilling holes, doesnt that defeat the purpose of a battery box? Its to contain acid in the event of leakage.
